Hose bib leaks inside home
When I open the shut-off valve (located in my basement) to spigot on the front of my house and open the spigot, I get a leak in my basement coming from the wall where the piping goes thru. Luckily my basement is unfinished so I can see where the water is dripping/leaking from. In the image below, i've circled the leak spot in red.
That said, when the cut-off valve is open and the spigot is closed, I don’t see a leak.
I know little to none about plumbing so I’m just trying to narrow down what the issue could be. Being that it doesn’t leak when the spigot is closed, does that provide any clues on where/what the issue could be?
Sounds like a hose bib valve body leak. It doesn't leak when the hose bib is shut off because it is a freeze resistant valve and shuts the water off at the valve entrance. That usually happens when the water supply pressure from the utility company is too high but also if the valve body is porous.
No man can be both ignorant and free.
Thomas Jefferson
Post Likes - 2 Likes, 0 Dislikes
Originally Posted by
WAYNE3298
Wayne, thank you for the response. Sounds like I need to replace the entire bib assembly (spigot and metal piping coming into the basement), is that correct?
That's what I would do. I would pull the old one first and take a look.
Thomas Jefferson
WAYNE3298
I would be doing the same as well. need to see what body of this bib looks like! Looks like a cheap brand, does that say prier ?
Sent from my SM-G960U using Tapatalk
Post Likes - 1 Likes, 0 Dislikes
Vinnie_NJ
Yes, its a Prier. Is that good or bad?
shobuddy
I never liked prier although they're claimed to be best made in the usa.. I normally go for shark bite, woodford, everflow.
This type of valve is a frost free sillcock. They're specially made to keep from having to shutoff water during the winter. Although that's very dependable on location and common sense too. Doesnt hurt to shutoff outside water supplies at first frost.
Most likely a hose was left attached in the fall. The hose stayed full of water, the faucet pipe stayed full of water. The water in the hose froze and expanded towards the wall faucet.
The water in the faucet pipe was compressed and split the pipe.
It only leaks when turned on. The water is shut off about 10-12" in side the house......the pipe is split between the handle and the shut off point.....that point is considered "freeze proof".
RLJN
X2....the frost free spigots don't drain water if a hose is left attached. One will notice that when you remove the hose with the spigot closed that a small amount of water drains out.
I have never had an issue with any of my frost free spigots and I remove all my hoses for the winter but do not shut the water off to the spigot upstream.
Sent from my SM-G965W using Tapatalk
three times over. also, if the line is not sloped downhill outward, water will stay in the valve and freeze.
Col 3:23
