+ Reply to Thread
Results 1 to 20 of 59
Thread: Using Stay Brite reconnect joint.
    Aug 2011
    Champaign IL
    Question Using Stay Brite reconnect joint.
    Have you ever taken apart a brazed joint and reconnected it with Stay Brite? Just curious.
    Southold, NY
    Quote Originally Posted by volts10 View Post
    Your going to have to get the silfloss hot enough to soften probably 3X the flow point of Stay Brite #8
  3. Likes stumpdigger, RMSG01 liked this post.
  4. #3
    Jan 2015
    Iowa
    Yes but why if it is really not necessary. The problem is two different filler metals, poor cleaning ability, lack of full filling of joint depth and potential leaks in the future. Just my opinion, I don't re-braze or re-solder joints if there is a choice
  5. Likes stumpdigger liked this post.
  6. #4
    Mar 2016
    Dayton Oh
    You have to get the joint hot enough to pull apart why not get it that hot again and cap with 15%.
    I love staybrite 8 but I only use it on bare copper super clean joints.
  7. Likes stumpdigger, dieseldude liked this post.
  8. #5
    Mar 2018
    Harris says in their literture on stay brite that it can be used to fill pin holes in braze which means it will wet on braze but I really think it would be way easier and more dependable to rebraze an already brazed joint.
    Sent from my SM-G960U using Tapatalk
    "I think Quantum tunneling would work great... "
    "Call a technician for God's sake. Or we'll see you on the news or the Dark Side of the Moon."
  9. Likes VTP99, stumpdigger liked this post.
  10. #6
    Southold, NY
    I know it will bond to silfloss the issue is cleaning it enough so it will bond!
  11. Likes DavidDeBord liked this post.
  12. #7
    Mar 2015
    Medford, N.Y.
    The path that the freon takes,from the inside of the system all the way out here into the atmosphere is stroon w/ debris. It is called oil,at least. How do you clean it up enough,to be able to get the new solder to resoldered?
  13. Likes DavidDeBord liked this post.
  14. #8
    Mar 2018
    Exactly I think it would almost be impossible. A wire brush in a drill would be your best bet but even that wouldn't get into all the rough areas left by braze
  15. #9
    Dec 2012
    columbus, OH
    Quote Originally Posted by TechmanTerry View Post
    Thats the beauty of brazing, by the time its hot enough its clean enough. There is no oil on a 900 degree pipe.
  16. Likes VTP99, R600a liked this post.
  17. #10
    Mar 2015
    Medford, N.Y.
    StayBright #8 melts at 430*f. At what temp does the new flux burn?
  18. Likes DavidDeBord liked this post.
  19. #11
    Southold, NY
    Exactly
  20. #12
    Southold, NY
    I thought it was closer to 600* but what do I know
  21. #13
    Dec 2012
    columbus, OH
    As far as im concerned your the aficionado for staybrite8.
  22. #14
    Southold, NY
    I was wrong
  23. Likes jackrussell liked this post.
  24. #15
    Mar 2018
    I was thinking around 600 as well for paste...the liquid flux is active up to 700. I use it to solder stainless and regular steel because you have to get steel hotter.
  25. #16
    Sep 2009
    Marietta, GA
    No, per literature ..it's about 430F...
  26. #17
    Jan 2020
    Winnipeg Canada
    Stay silv...... 45% silver. I use that anywhere critical.
    Especially old failed solder or brazes or somewhere that's been broken like a condenser.
    It's also fantastic for repairing condensers without having to remove fins.
  27. Likes dieseldude liked this post.
  28. #18
    Southold, NY
    Big difference between Stay Brite and 45%
  29. #19
    Jan 2020
    Winnipeg Canada
    Yes very big difference. I'll occasionally use stay brite on 134 cap tube systems inside a kitchen. Especially since everything there is covered in grease.
    But any system capable of more pressure I won't waste my time or the customers money.
    Been seeing it alot on new r290 systems. The solder joint's keep cracking. And it's a total pain to braze properly after the factory soldered the joints lol
  30. #20
    Oct 2011
    Chicagoland Area
    The real question is Why?
    Why is it that those who complain the most contribute the least?
    MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
  31. Likes stumpdigger liked this post.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
