You need to check with a dealer but chances are everything is getting replaced.
Hi,
I have a Fujitsu outdoor condenser, model #: AOU36RML1, that needs to be replaced. I found out that this model has been discontinued. Does anyone know of a compatible model that I should get to power two, model #: ARU9RML, mini-split, heat pump concealed ceiling units and two ASU9RMLQ units.
Thanks,
Mark
R I P Icemeister
Supporting our Vet’s
http://www.soldierride.org/
http://www.woundedwarriorproject.org/
Your question will best be answered by your contractor as he will have to take responsibility for the compatibility and installation.
https://www.hvac20.com/ High efficiency equipment alone does not provide home comfort and efficiency. HVAC2.0 is a process for finding the real needs of the house and the occupants. Offer the customer a menu of work to address their problems and give them a probability of success.
Find contractors with specialized training in combustion analysis, residential system performance, air flow, and duct optimization https://www.myhomecomfort.org/
The issue is usually communication between the indoor and outdoor units. A new outdoor unit may not properly communicate with old indoor units.
Have your deal contact Fugitsu to find out.
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.
Thank you for your replies.
