Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 85
Thread: I'm not Proud to do this...but customer could not afford new system or coil.
  1. #61
    If you stick them together with a bead of silicone caulk - that will stop happening.
    Quote Originally Posted by Pnasty View Post
    Saw it on a dual pressure control where each cap tube had rubbed through and been repaired 3 times.
    PHM
    The conventional view serves to protect us from the painful job of Thinking
  2. #62
    May 2014
    Bay Area California
    I just put a tie wrap or two on it.
    I do a triple evac with nitro to remove non condensables.
  3. #63
    Jan 2010
    or just make sure their not touching each other ....
  4. Likes Achso017 liked this post.
  5. #64
    Mar 2013
    Treasure coast, FL
    Even cap tubes need to socially distance.
    Sent from my Moto Z (2) using Tapatalk
  6. Likes Achso017, BBeerme liked this post.
  7. #65
    Jan 2010
    Quote Originally Posted by shellkamp View Post
    Good luck with that 🙄
  8. #66
    May 2014
    Bay Area California
    Those cap tubes need to be thrown in prison. We'll let some felons out of prison to make room.
  9. #67
    Sep 2009
    Marietta, GA
    Quote Originally Posted by Fvaladao View Post
    Your customer couldn’t afford it. Did you fix it for free.
    I can see at least 4 to 5 hours of labor, adding R-22 and as preventative maintenance maybe you added the easy seal.
    I didn't fix it for free. I gave them a flat price for the repair with a new FD and r407c. I just took my sweet time and got it squared away properly. I haven't heard back from them since then. Everything is still holding up. It's a old Bryant HP system. I think it's about 20 yrs old.
  10. #68
    Jul 2009
    New Orleans
    Quote Originally Posted by BNME8EZ View Post
    A tip I got from this site years ago for nicked distributor tubes. Strip out a section of #18 stat wire. Wrap it around the tube where the leak is keeping the wire tight to itself. Then solder over the whole thing. The tight wrap on the wire keeps the solder from entering the distributor tube. I have done it a couple times.
    Pretty good idea
  11. Likes Unlimited1 liked this post.
  12. #69
    Dec 2003
    Citrus County, Florida
    I carry small copper and cap tubes for exactly that reason. An expander also helps. Do what you can as not everyone can afford a new coil or system. This also helps change TXV's and equalizer tubes.
    Doug
  13. #70
    Sep 2009
    Marietta, GA
    BTW.. that system already leaked out flat again at the beginning of last yrs Winter. LOLL
    wHen I diE I hOpe gOd haS mErcy oN my SiNful LifE
  14. #71
    Sep 2012
    thomaston, ct
    You did good for what you were presented. Blame that on the installer for not inspecting that coil before commissioning.
    A little late to be blaming the installers for that one!
    I’ve seen plenty of newer units with friction holes on cap tubes, not installers job to disassemble a new unit to make sure it was built correctly.
  15. #72
    Sep 2012
    thomaston, ct
    Quote Originally Posted by mofotech View Post
    I would use the uv dye alot when I was new in the field. But later on and after a few messy dye situations I stopped using the dye. Now just my leak detector and big blue. If system last until end of summer after a refill then I will do isolation tests as that's the most guarantee way in finding a leak ; especially a stubborn one.
    Must have been the first or second time I used dye, disconnected hose and dye was under pressure and it exploded all over me, doctors office staff were worried, I found the leak but my ego left bruised.
  16. Likes mofotech liked this post.
  17. #73
    May 2014
    Bay Area California
    Wrong. Anything can happen during shipping.
    Quote Originally Posted by jlanesey View Post
  18. #74
    Jan 2010
    Oh contrary, it's in many IOM'S to do inspection.
  19. #75
    Aug 2009
    Beatrice, NE
    Yeah, I have seen tube rubs on new systems as well as on system that originally had none. Best practice is if you are looking at cap/distributor tubes for any reason to check for tube rubs.
  20. #76
    Sep 2012
    thomaston, ct
    Quote Originally Posted by BBeerme View Post
    Heroic post, love the red text. Doing a inspection of above coil wouldn’t have prevented this 10-20 year failure. Again, not my job to do QC in the field, I’ve got a lot of other things to worry about to make sure the customer is getting a quality install.
    I always check the basics, damaged cabinets, blower wheels centered on the shafts, pressure test on coil, if there is a manufacturers defect that doesn’t present itself for 10 years you should be pointing your finger at the manufacturer not the installer.
  21. #77
    Sep 2012
    thomaston, ct
    So you would have cut off the manufacturer installed zip ties on the coil knowing that would prevent a failure in 20 years, give me a break. Installing equipment “correctly” isn’t an easy job. Hot shot service techs blaming every problem they ever see on the installers gets old quick.
    I can’t even begin to count how many times I’m there to change out equipment that the all star tech red tagged solely because they didn’t feel like fixing or were gunning for a commission.
  22. #78
    May 2014
    Bay Area California
    If you are not inspecting the coil, and associated distributor tubes during an install, you are not doing a quality install.
    In commercial, I'll look at the distributor tubes on a rather frequent basis. That's why it is called a PREVENTATIVE maintenance. If I did residential, I'd only look at those tubes if I had reason to pull the panel off.
  23. #79
    Apr 2020
    Garner NC
    I gut the AH in commercial and some residential settings because of where they are located and lighter to fit in easier! Everything gets inspected and flipped where necessary at that moment ....but I inspect everything when it comes out of the box due to concealed damage...
  24. #80
    Sep 2012
    thomaston, ct
    So again, you would have cut off the zip ties that were installed by the factory knowing it would cause a problem in twenty years?
    Every install you do you pull the evap from the air handler to inspect both sides of the coil? You pull the jacket on every condensor to make sure no tubes are rubbing?
    If I had that little confidence in what I was selling / installing I’d be looking for another brand.
