+ Reply to Thread
Results 1 to 2 of 2
Thread: U41 - burner will not light
    Mar 2020
    sf bay area
    Regency U41. 910-028 valve per part diagram. Robert Shaw valve.
    Pilot lights and holds solid flame. Yes - moved to "on".
    When turn on switch main burner does NOT light.
    TH - TH/TP when off is 330-335mv
    TH - TH/TP when on is unchanged. I would expect a drop to fire solenoid.
    Ohm-ing out switch leads...
    Switch when off : TH - TH/TP OL
    when on: 0 ohm
    But shorting switch terminals across valve also doesn't light main burner.
    that is th-th/tp
    Pile voltage seems low but puzzled why i don't see a drop across the thermopile when I turn switch on.
    S.E. Pa
    We can't give DIY advice here. See Site Rules. You are testing incorrectly. None of what you posted makes sense. If you are a tech, get your post count up so you can post in the Pro forums where we can explain and give technical advice.
    Meanwhile, you need to review a technical manual on the RS valve.
    Could be spiders blocking the orifice .
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
