Results 1 to 13 of 13
Thread: Creation of Niagara 4 module
    Feb 2014
    Hi guys how are you?
    I hope you can help me, I am looking to transform some java classes into modules that I can see inside Niagara 4, but I have not found any documentation about it.
    Thanks for listening
    Greater Atlanta Area
    Feb 2014
    Thanks, for the tip, but my doubt remains, I create the module in the wizard, I open in eclipse I create the java class and export it to jar and even then, the file does not appear in modules, I think I'm missing something.
    Did you look here:
    https://www.niagara-community.com/ar...and-Components
    it walks you through how to create a module and install the Niagara Plugin for Eclipse.
    Apr 2019
    Glasgow, Scotland
    Quote Originally Posted by controlgeek View Post
    Did you look here:
    Thanks for the link, been looking for some information on this myself. Everything i read about the eclipse plugin mentions 3.8, is it the same plugin used for N4 ?
    I do not believe it has changed for N4 but my understanding from when I attended the developer course that a majority of the Niagara developers at Tridium are now using IntelliJ which does not have a plugin.
    Feb 2014
    Did you look here:
    Thanks for the link, I was using this material, I am also not using the plug-in, no material is necessary to do the full build, I think that is exactly what is causing my problem, as I do a full build without a plugin, there is any command on N4 for that?
    Feb 2014
    Quote Originally Posted by Jeffdantonio View Post
    Thanks, guys, I found out that I need to create the module in niagara and open it in eclipse with a gradle project instead of a java project to access the build function
    Feb 2012
    I too am now trying to figure this out. Can anyone re-cap what is required to get this working? The documentation is very lacking with respect to N4.
    Aug 2022
    Hello Guys...
    Are there any tutorials available for developing jar modules for N4? What tools do I need along with N4?
    Thanks in advance!!
    Apr 2015
    Omaha, NE, USA
    Quote Originally Posted by Jdeep View Post
    Hello Guys...
    Thanks in advance!!
    You will need to download IntelliJ IDEA and then start with this github repository:
    https://github.com/tridium/summit18-...ev-environment
    I would also register with Tridium to access documentation, although it is outdated (uses Eclipse IDE and plugin instead of IntelliJ):
  12. Likes Jdeep liked this post.
  13. #12
    Sep 2013
    There is a Niagara developer class you can take too.
    Sent from my iPad using Tapatalk
  14. Likes Jdeep liked this post.
  15. #13
    Aug 2022
    Thanks!
Tags for this Thread
