Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
Likes (Given)
51114
Likes (Received)
14501
Dislikes (Given)
0
Dislikes (Received)
25
Can you explain a bit more?
What is an HPCU? (High pressure condensing unit?)
Sent from mars using Tapatalk
"Is this before or after you fired the parts cannon at it?" - senior tech
I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
Unless we change direction we are likely to end up where we are going.
"It's not new, it's better than new!" Maru.
Likes (Given)
51114
Likes (Received)
14501
Dislikes (Given)
0
Dislikes (Received)
25
Heat pump condenser?
That makes more sense.
Likes (Given)
51114
Likes (Received)
14501
Dislikes (Given)
0
Dislikes (Received)
25
This is an intriguing idea.
How will you take care of condensate?
Also what humidity are you aiming for or is humidity not important for this application?
Membership Chair/ARP Committee / Professional Member*
I try to stay as far away from myself as I can.
Likes (Given)
441
Likes (Received)
11527
Dislikes (Given)
5
Dislikes (Received)
27
Why put the condensing unit inside the 40º box? Wouldn't an AH take up less room? And where will all the condensate water go? Onto the floor?
No wait; it's worse than that: a HPCU is not designed to be wet all the time - it generally frosts and defrosts and dries out inbetwen.
And really; the best way to do this would be with a standard refrigeration coil hanging in the box.
And "dumping heat" into a kitchen might be quite the trick to accomplish as these are often near 100º F. in the summertime.
I have a number of times myself (refrigerate with AC equipment) and I've seen it done all over the Caribbean islands. You can run the box very cold and defrost it in a minute by switching the reversing valve. Or . . . you can just use a large evaporator, run a low TD, and not even need to use a heat pump. <g>
PHM
Originally Posted by timjimbob
This will work.. Just need someone to do it for me.
Put a outside HPCU inside a walkin cooler box. Put AHU in the Kitchen to dump heat.
Parameters are within range. HPCU will have ambient of 35-40. AHU ambient is 78-80 degrees.
I like it because HPCU is waterproof and set-up is much cheaper than refrigeration equipment.
Who will do this for me?
PHM
When faced with the choice between changing one's mind, and proving that there is no need to do so, most tend to get busy on the proof.
AHU is not designed to operate at 40 ambient. HPCU is designed to be outside at 35 degree weather. Defrost water goes down floor drain. I don't think I can buy refrigeration equipment as cheaply as I can get builder grade HP.
Likes (Given)
51114
Likes (Received)
14501
Dislikes (Given)
0
Dislikes (Received)
25
Like PHM said use the air handler or refrigeration evap with standard refrigeration defrost controls.
80 degree kitchens are common.
Likes (Given)
51114
Likes (Received)
14501
Dislikes (Given)
0
Dislikes (Received)
25
Why don't you do it? You are a contractor.
Likes (Given)
441
Likes (Received)
11527
Dislikes (Given)
5
Dislikes (Received)
27
That logic escapes me. What about AH design would prevent it from working properly in a 35º ambient temperature?
What you describe can be made to work but it's not how I would go about it.
PHM
PHM
I buy used refrigeration equipment all the time. Quite often it's in new condition from a failed restaurant venture.
Why even waste time / money reinventing the wheel ?
I just moved this unit today. Probably paid 100.00 and it's never been used.
The thing you call a heat pump condensing unit is actually going to be an evaporator. The real condenser (the thing you will be putting in the kitchen) is designed to have a return air temperature of about 70°F.
You state that this kitchen will be 80°F? That's pretty good as far as kitchen temps go, but it's pretty horrible for a heat pump air handler. That's right on the ragged edge of where that thing will be able to function without tripping it's high pressure switch (if it has one).
Hey, I just came up with an idea for you. Instead of a "condensing" unit and an air handler, Why not get yourself 2 "condensing" units? One inside of the box and one on the outside. That way you will be good for a kitchen temperature of around 110° or so (and you'll have a spare compressor for "just in case").
Just make sure you have really high ceilings in that kitchen (and inside of the cooler) to avoid recirculation issues.
Great idea!
If at First You Don't Succeed, Skydiving Is Not for You.
Likes (Given)
441
Likes (Received)
11527
Dislikes (Given)
5
Dislikes (Received)
27
Brillant!
So all you would need would be a lead/lag arrangement to alternate compressor operation and have a nice amount of redundancy.
PHM
Hey, I just came up with an idea for you. Instead of a "condensing" unit and an air handler, Why not get yourself 2 "condensing" units? One inside of the box and one on the outside. That way you will be good for a kitchen temperature of around 110° or so.
Just make sure you have really high ceilings in that kitchen (and inside of the box) to avoid recirculation issues.
Great idea!
PHM
Why not just do it as a straight cool unit? The kitchen is already full of hot air. I'm sure another heat source of 130* won't affect it that much.
Why is it that those who complain the most contribute the least? MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
Because he wants the condensing unit inside the walkin box.
My bad.....
