Results 1 to 20 of 49
Thread: Second opinion appreciated - 11yr old gas furnace needs replacing?
    Dec 2019
    Hello all,
    This is my first post but I really did not know where to turn to. So your expertise would be very much appreciated and forgive me for the newbie long post.
    Background:
    I have an 11 yr old American Standard UH2C100A9V4VA gas furnace which was installed in 2008. The gas furnace functions as aux heat to our heat pump system which kicks in above 35deg. The original install company closed a year later when the owner retired.
    In the last 1.5 years, I've had both the flame sensor and igniter replaced twice by different technicians who seemed to think that was the only issue. Both times, when the flame sensor was replaced, the the igniter then seemed to not work, so then that was replaced. Then the system would work somewhat better. but the issue remains that the furnace still doesn't ignite immediately sometimes and its predictability seems to be random, which makes it impossible to go away from the house in winter. (The only error code I ever got was two red flashes - system lockout - after it fails trying to start 3 times.)
    Many visits and several thousands of dollars later, the most recent "senior" tech from our propane company said the issue seems to be flame blowback on the flame sensor and he thinks it's due to a hole or crack in the heat exchanger (he saw some rust on it). The recommendation is to replace the furnace (they will give us a break on the pricing if they do the installing) and sited CO2 danger, etc.
    While we are waiting for an estimate from them, right now the furnace is starting upon 1st or 2nd try.
    Does all this ring true/legit to you? Thank you in advance for your thoughts.
    Southold, NY
    Before spending a LOT of money get a second opinion.
    Dec 2019
    Yes, we plan on doing so but the issue is we don't know who to trust since the community is small and the business owners seem to all know each other... I fully realize that no expert can accurately diagnose over reading a problem online, but just wanted to know if this seemed fishy or legit. Thank you
    Jun 2014
    Dover, DE
    I’d get a second opinion. Not normal for the heat exchanger to fail after just 11 years.
    Other things can cause rollout conditions.
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    Southold, NY
    Quote Originally Posted by Ang2277 View Post
    As far as Im concerned over 1/2 of the contractors out there are not qualified.
    When you find one hold on tight.
    Dec 2019
    (sorry double post)
    Dec 2019
    "I’d get a second opinion. Not normal for the heat exchanger to fail after just 11 years.
    Other things can cause rollout conditions"
    Even if they saw "rust" on it? They said they planned on coming back with a camera to check for holes or cracks, but then their manager called and recommended a full furnace replacement.
    VA
    Are you kidding me? They want to replace your XV95 because they can’t fix it?
    They likely installed a generic replacement igniter, not the oem. Trane/ AmStd. uses a logic control that reduces voltage to the igniter for maximum efficiency. If the oem igniter is not used it will likely show/cause random failures. Your furnace doesn’t even get much use because of it being in dual fuel configuration. So, it should likely last much longer.
    Sounds to me like you need a Trane rep take a look before dropping big bucks on a replacement.
    "The only true wisdom is in knowing you know nothing" Socrates
    Those are great furnaces though propane is harder on furnaces than natural gas. But I agree, somehow find a great tech to figure it out. American Standard suppliers are supposed to have a tech rep on staff to help local dealers on cases like this. Ask who sells the equipment to them and if that supplier has a tech rep.
    Dec 2019
    Quote Originally Posted by mgenius33 View Post
    Thank you so much! This information is very helpful. We're waiting for a callback from a Trane authorized place but good to know about this.
    Jan 2014
    New England
    Believe that furnace came with a limited lifetime HX warranty to original owner if registered, if never registered should have a 20 year warranty, course dont know what they would charge for the labor and what not.
    Dec 2019
    Drats - we just checked the igniter number (on the plug) and it's an OEM IGN-0145 / IGN-0117 Replacement so it's the right part. Was so hoping that was the culprit.
    Jul 2010
    nebraska
    Heat exchanger is under warranty. You'll have to pay 3 hours labor tops to change it. Whole lot cheaper than a new furnace.
  14. #14
    Dec 2019
    Quote Originally Posted by martyinlincoln View Post
    Thank you, we are checking on the warranty now and see what our coverage is.
  15. #15
    Dec 2019
    It's been very hard to get in touch with an American Standard furnace dealer/techs in our area! No return calls and the American Standard website is a labyrinth of redirects. We will keep trying.
    FYI - the propane company casually said "you know we can get your house condemned" implying that if we don't get our furnace replaced by them then they will cause issues for us. Interesting tactic.
  16. #16
    Southold, NY
    Tell them to do it!
    Then contact your Attorney General and tell them you've been threatened!
  17. #17
    Aug 2009
    Beatrice, NE
    I would want to see a Combustion Analysis done before condemning anything for starters. Barring that there are other ways to check the heat exchanger for breaches that may not be seen with a camera.
    Second LP is hard on burners etc, I wonder how clean/rust free the burners are. Then with LP pressure can be a huge issue on some units. If the incoming pressure is to high or low or if the manifold pressure is off the burners don't like to light.
    The other thing just thinking out loud is venting can cause problems.
    So the bottom line is there is a myriad of things that it could be.
  18. #18
    State College, PA
    If you think there might be a safety issue, make sure you have CO detectors in the house especially around the sleeping areas.
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://hvac-talk.com/aop
  19. #19
    Dec 2019
    Quote Originally Posted by BNME8EZ View Post
    Thank you for your input!
  20. #20
    Dec 2019
    Quote Originally Posted by joemach View Post
    Yes we do have CO detectors on each floor including the basement near the furnace. For the upper floors, is it more effective mounted low?
Tags for this Thread
