Hi! I'm going to try and make this as short as possible because this situation is driving me up a wall. Installed this Neo UY0140A-161B in 2014 and outside of replacing a pump a few months ago (Manitowoc Ice 040006556 Kit) it's been reliable. There's an issue that almost always happens after a cleaning and sanitizing and I can't figure it out. The problem usually corrects itself, but this time it's not happening. The machine is cleaned and sanitized 3-4 times per year and it's done by the book. A run with nickle safe cleaner, shut down the machine. Remove Water Distribution Cover, Water Trough, Ice Damper, Evaporator Side Damper Mount, Harvest Float and Ice Thickness Float... soak in cleaner, rinse, dry, spray with sanitizer and allow to air dry. The inside of the machine is then sprayed with cleaner, rinsed, and dried. The inside of the machine is then sprayed with sanitizer and the solution is allowed to air dry- NO RINSE! Parts taken out are then put back in and a cleaning cycle with sanitizer is then run through the machine. After that the machine is allowed to start producing ice. What usually happens within 24 hours or less is that a large block of ice forms on the evaporator. I get a call that this happened and I say to shut it down and let it thaw out. The machine is then powered back on and sometimes it will operate normally and sometimes it will produce another large block of ice, but has up until this point always eventually (within the day) worked itself out. I don't get it! The machine is always working just fine prior to the cleaning. It's cleaned so often and thoroughly that it never accumulates any minerals, slime, nothing. So this time the large ice formation on the evaporator situation works itself out as it always has, but now the ice being produced has a bridge thickness of 1/4" or slightly larger. Frustrated, I decided to replace both the Harvest Float and the Ice Thickness Float (new parts) and yet I still have the same result with a bridge that's way too thick. The Harvest Float is in the correct position and the Ice Thickness Float is positioned to produced the smallest cube. The machine is level, it's never been moved from the position is was installed in. I don't understand why this happens after a cleaning. I made a video and I have two pictures showing the situation, but it seems rules don't allow one to post links or pictures unless you have at least 7 posts. I am very sorry, but I am short on time and would greatly appreciate getting the video and pictures to someone... anyone!
. Any help is greatly appreciated!
