Thread: Mini split relocation question.
    Nov 2019
    Confused Mini split relocation question.
    I have a mini split condenser unit sitting on a flat roof of a town home. Since we are planning to reroof the entire area, we will probably need to move the condenser. My question is are those copper pipe connected to the condenser bendable? The roofers said he can just leave it up for a feet to do the roof work, but I want to check for expert opinion here.
    Jun 2000
    WYO
    It would be best to hire a local Co. to supervise any movement. A leak at the unit is a common problem as is kinked copper tubing. Depending on line length and position, it may be able to be moved and supported briefly, may also not. A HVAC contractor can ensure everything goes smooth before and afterwards with that, and electrical wiring and condensate drainage.
    Ask the roofer if he will warranty issues caused by his moving of equipment.
    Southold, NY
    Are the roofers going to guarantee "No Issues" They cant!
    Have your Contractor raise it up on Pump Ups (Should have been done from day one) The roofers can flash it in!
    Moved to AOP.
Tags for this Thread
