Results 1 to 8 of 8
Thread: how fix broken faucet?
    Sep 2009
    Feb 2017
    New York
    You could replace the cartridge. If it doesn't come with a new screw, match one up at HD or somewhere.
    Sent from my SM-G935U using Tapatalk
    -----Stop, step back, relax and have another go at it.-----
    Sep 2009
    cant get it out
    New Jersey
    They make a tool that you insert into the two flats that allows you to spin the cartridge. Usually after you are able to spin the cartridge, it frees it up.
    Check with a good plumbing supply house for this tool. If you get a replacement cartridge it comes with a plastic tool, the plastic tool will break, ask for a metal one. Also penetrating oil will help to free up the rubber gaskets.
    Sent from my ASUS_P00J using Tapatalk
    Jun 2020
    Heres a set of pro tips in order to do repair.
    1- make sure water to home is off.
    2- drain some water in home to alleviate pressure
    3- Tap broken screw lightly with a screw driver handle or flat head driver and a wrench. This is to loosen the hold on the threads.
    4- if this does not work- you use a dremel to cut a flat blade shape into the screw.
    5 - thread out screw.
    6 - Remove clip on top (horseshoe shape).
    7- Make sure to utilize moen cartridge puller - it appears you have a 1222B cartridge. These are common.
    8- Clean and lubricate valve body- then reverse your steps making sure to note the “H” must be at the 9 o’clock position when installed.
    9- Take me out for Starbucks after singing in the hot shower you had; knowing you saved 200.00 not calling a plumber.
    Jul 2018
    NW Louisiana
    I was going to say, Bathroom Remodel, but Calgaryhvac seems to have something cheaper... LOL
    Jun 2020
    30 minutes or it’s free
  8. Likes RMSG01 liked this post.
  9. #8
    Jul 2018
    NW Louisiana
    Quote Originally Posted by Calgaryhvac View Post
    I never was late delivering pizzas, even if they handed me 3 to deliver at different locations.
