Thread: New Home Construction
    Sep 2019
    SC
    Hello, and thanks in advance. Should new home wireing setup have a whole-home surge protector or is that what the electrical pannel does? Also, if you have any suggestions on what you would do during construction, they would be greatly appreciated. It will be a downsized small home with smart tech. Thanks, D
    Athens, Ohio
    The breaker panel does not include surge protection. That is an add-on device.
    https://www.hvac20.com/ High efficiency equipment alone does not provide home comfort and efficiency. HVAC2.0 is a process for finding the real needs of the house and the occupants. Offer the customer a menu of work to address their problems and give them a probability of success.
    Find contractors with specialized training in combustion analysis, residential system performance, air flow, and duct optimization https://www.myhomecomfort.org/
    Site member map HERE!
    Oct 2019
    The surge protection does not provided by electrical panel.. You have to do the internal wiring and attach with it surge protection wires. The suggestion is to hire a professional so it should be done properly.
