Results 1 to 19 of 19
Thread: New Build Hot Water
    Sep 2019
    SC
    New Build Hot Water
    Hello, and thanks in advance. Trying to decide on a tankless water heater and a traditional water heater. Home will be small and used by 2 people. All recomendations will be considered when making my final decision later this year. Thanks again for everyones input. Forums have helped me make correct decisions in the past, D
    Apr 2003
    Maple Grove, MN
    In one of your other posts you mentioned that you liked "smart tech". Just based on that I think you should go tankless, since they come with a little computer built into them and all kinds of fancy technology.
    There are good things to be said about traditional tank type water heaters such as they are more simple, reliable and they cost less to purchase, but they are also boring, and I'd bet that might be a deal breaker for a guy like you.
    Good luck!
    If at First You Don't Succeed, Skydiving Is Not for You.
    Jul 2018
    Wisconsin
    How is the home heated? boiler? Forced air?
    Sep 2019
    SC
    Spitz, it will be heated forced air natural gas
    Jul 2018
    Wisconsin
    Ok was asking because there are combination appliances. We just installed a few combi boilers and a combi forced air furnace/Water heater. They were all NTI the furnace/Water heater was A NTI GF200. If you dont want to do a tankless there are options for a high efficiency tank water heater. We have done a few Phoenix water heaters by HTP they seen to be a solid unit.
    Jul 2018
    Wisconsin
    Basement?
    Sep 2019
    SC
    no basement
    How is your water quality?
    Hard with minerals?
    High Acid?
    Sulfur?
    Anything like that?
    Has a water sample been quality lab tested?
    PHM
    Quote Originally Posted by Air? View Post
    PHM
    The conventional view serves to protect us from the painful job of Thinking
    Sep 2019
    SC
    PHM, water quality is great. Never had it tested. Tastes great and is less filling..... its not hard water, no sulfur taste or smell, some of the best water in the States here in SC except at the beach! The 50gal water heater I have now is 19 years old with no issues. I have read about tankles, but I am not convinced yet. Thanks for all responses, D
    Without water quality issues - I would only install a tankless. It doesn't make sense to me to keep a big tank of water hot Justin Case someone needs it.
    PHM
    PHM
    Sep 2019
    SC
    Thanks Everyone!
    Jun 2012
    Northern NV
    Not Rinnai... Have 3 of the condensing ones and they are the most horrible ones I have ever had to replace a HX on. And Rinnai said that the HX would not be covered as we did not flush the HX with vinegar every 6 months and take the blower off and clean it out. Manual says clean every year...
    Not sure who make a service friendly tankless, perhaps some one will chime in with a good experience?
    I have had a non-condensing Tagaki tankless in my house for more than ten years and I have literally never touched it. No flushing; nothing, and it has never missed a beat. I do have really excellent water.
    I installed one just like it for a customer one town away and they have had the same experience.
    All the other's I have installed have been been condensing Naviens. None, to my knowledge, have ever had any maintenance or repairs done on them and all are still working well.
    PHM
  14. #14
    Aug 2001
    Pavilion, NY
    I'm with mikey, I also have a takagi 80% for 12yrs. Probably 6 years ago I flushed and serviced it and it seemed like a waste of time. They are great. At the end of the day, you probably will not save much money with a condensing unit unless you use tons of water. In my opinion, the added complexity of a condensing tankless does not justify the added cost.
    Sent from my SM-N960U using Tapatalk
  15. #15
    Plus; for me it made zero sense because I added a little plate-frame heat exchanger and a bronze circulator to make 'boiler water' to supply a large water coil in my second floor air return. So: no condensing as the return water is only 20 cooler than the supply.
    Wait; I guess that is really another vote for Tagaki as I Really run the poop out of mine - considering that it also heats half my house. <g>
    Oh! I forgot - my Tagaki just tempers water from my solar heated tanks. So it would never condense anyway - unless the sun didn't shine for a week. <g>
    PHM
    Quote Originally Posted by kangaroogod View Post
    PHM
  16. #16
    Aug 2001
    Pavilion, NY
    PHM
    Show off
  17. #17
    What is the point of doing anything if not to show off? Even if it's just to yourself. <g>
    Show off
    PHM
  18. #18
    Jun 2020
    You may want to consider a long term budget as well. Tankless heaters require maintenance. Also, they seem to break down often.
  19. #19
    Jul 2018
    NW Louisiana
    PHM
    PHM, the only time a tank water heater matters is, in a zombie apocalypse, once everyone leaves the area, go and turn off all of the main shut offs to the homes so you don't back feed into the main supply and you'll have plenty of drinking water for a while, outside of that, tankless is the way to go.
