Results 1 to 12 of 12
Thread: Vacuum with coremax
    Aug 2019
    Vacuum with coremax
    With all of this info on proper vacuum pulling what do people use when there is a coremax fitting? Does anyone put new service ports? I usually pull Schraders if available for using the vacuum hoses
  2. Likes CEAS-AC-TECH liked this post.
  3. #2
    Jun 2011
    michigan
    Coremax is already a high flow port. No need to pull. And can't pull and pull vacuum anyways.
  4. Likes CEAS-AC-TECH liked this post.
  5. #3
    Jan 2002
    Chicago area, Il.
    It has been recommended to use core depressor tools, to insure the core is fully open, and the C.D.T has much less restriction to flow than the depressors in the end of a hose.
  6. Likes R600a liked this post.
  7. #4
    Aug 2008
    I've also been searching for what others have figured out on this problem. Any suggestions on vacuum rated core depressors? There's plenty of vacuum rated core remover tools but the other I'm struggling with...
  8. #5
    R600a's Avatar
    R600a is online now Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    If you're pulling a vacuum my only question is why didn't you cut them out and braze in some schraders?
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
  9. Likes dieseldude liked this post.
  10. #6
    On a bull named Foo Manchu
    Quote Originally Posted by R600a View Post
    If you are going to why a shraider and just go for it like ⅜ or ˝ service valve? I'd probably just use a core depressor and vacuum hoses.
  11. #7
    Aug 2008
    Not every situation allows for time or the option to do this. That said, that wasn't my question... 😂
  12. Likes R600a liked this post.
  13. #8
    Dec 2021
    Richmond, VA
    Quote Originally Posted by griffon26 View Post
    I’ve used the Accutools Depressors, from TrueTechTools, for years and haven’t had any issues with pulling quick vacuums thru core max fittings.
  14. Likes R600a liked this post.
  15. #9
    R600a's Avatar
    Jul 2019
    Quote Originally Posted by dcipherrva View Post
    They make a darn good core depressor.
    I had one but I gave it to my boss's son because I'm afraid he's going to lose a hand from frostbite one of these days.
  16. #10
    Aug 2008
    Thank you!
  17. #11
    VA
    I don’t understand why these valve core tools are $400-$600! Really?
    "The only true wisdom is in knowing you know nothing" Socrates
  18. Likes R600a liked this post.
  19. #12
    R600a's Avatar
    Jul 2019
    Quote Originally Posted by mgenius33 View Post
    Seriously. That's more than my oxy acetylene rig which I use to replace them.
