Results 1 to 7 of 7
Thread: Underground Pipe; Ductile Iron Pipe vs K Copper Pipe
    Jun 2002
    Dacula, GA
    Which is more preferred in the 4" to 8" range? Total cost, longevity, etc. How about it aces? Thank you very much
    Sen. Barry Goldwater
    Jul 2018
    Wisconsin
    Poly.
    Sent from my SM-G960U using Tapatalk
    Jan 2010
    You doing a water line ?
    Atlanta GA area
    We do not chase plumbing work...
    However what I see with replacement of water lines (small)...
    Is PEX.
    Not sure if that is what you are asking about...
    GA-HVAC-Tech
    GA's basic rules of home heating and AC upgrades:
    *Installation is more important than the brand of equipment
    *The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
    *The value of comfort, over the long term; leave economic choices behind!
    Choose your contractor wisely!
    Feb 2016
    Louisburg Kansas
    I would use PVC type or FRP underground. With iron type you have to worry about cathodic protection. Coatings are OK unless you have a holiday (flaw) in the coating and then the pipe will deteriorate rapidly at that point.
    No man can be both ignorant and free.
    Thomas Jefferson
    Jan 2010
    Quote Originally Posted by WAYNE3298 View Post
    I had to repair a leak on a 6" underground cast iron water main.
    Seems a limestone had been up against it all those years and corroded a hole in it. By the time we got the water off it was a 30' geyser. Bought a stainless band that goes around the pipe and gets bolted together.
    Feb 2016
    Louisburg Kansas
    Yeah VTP99. Once a cell action gets started the result isn't pretty. Several years ago I designed a tower water system that had buried 24" diameter schedule 40 steel pipe. The design included a state of the art cathodic protection system that failed the test for adequate protection. Ironically after a lot of hair pulling trying to figure out why the contractor called and said the wire securing the ID tag for the isolation flange where the pipe entered the ground was wrapped around both sides of the flange. That of course defeated the protection. He removed the tag and all was good.
    Thomas Jefferson
