Hello and thanks in advance for your input/answers.
I have a 2.5Ton unit (model No. 13AJA36A01 Rheem/WeatherKing) that stopped working. Earlier today the unit would not turn on, so after some troubleshooting, I called my AC tech to come out and take a look at it. After some diagnosing, my tech informed me that the compressor died. He mentioned that the compressor had a short circuit which caused the failure. He also mentioned that since my system is R22, they no longer make replacement parts, and even if we found a replacement, the cost would be similar to installing a new system. After some searching in craigslist/Offerup, I found a local HVAC guy that sells used compressors (R22) at reasonable prices. Do I have to use the same OEM compressor or can I use a different brand as long the compressor is rated for the same tonnage? Looking for alternative solutions as I dont have the $ plus that it will cost to install a new unit. I'm in South Florida, so I need to find a solution asap. One last question, how much freon (r22) do i need for a 2.5T system?
