Thread: Soldering flux
    Oct 2001
    Soldering flux
    I know that lately a lot of plumbers uses propress and PEX but here is a question to those who still sweat copper pipes:
    What kind of flux do you like the most? What do you think about water soluble flux?
    Is anyone using tinning flux? Thanks for sharing your opinion.
    Madison In.
    I like the tinning flux, but don’t do much water anymore.
    Dover, Pa.
    The only solder made anymore worth anything is the purple label “sterling” brand, all others flow too easily and won’t fill a small gap in the joint. Sterling flows like the old 50/50 used to.
    No need to use anything special when tinning a larger joint, just regular flux and solder.
    Good mechanics are getting harder to find.....have you encouraged or discouraged a young mechanic today?
    May 2019
    Detroit, MI
    Harris Stay-Clean
    Oct 2016
    Clearwater, Florida
    I use some Oaty flux, comes in a small bucket.
    I tried tinning on on one job but with multiple pipelines and lot's of fittings, I would do one side of an elbow and then the next, then the fitting close to it would have a silver ring and I would think I had done it, move on and so forth. Ended up missing 1 or 2 joints, in the toughest to get to location, so after that I stopped using it.
    Apr 2003
    St. Louis
    Any name brand. Really haven't seen much of a difference
