Results 1 to 20 of 23
Thread: Navien
    Caledonia WI
    Navien
    Real fasteners holding this one up, I thought the ones included for mounting it were just strong enough for a thermostat...
    It's not what you're capable of doing that defines you, it's what you do on a daily basis.
  2. Likes kangaroogod liked this post.
  3. #2
    Jun 2014
    Dover, DE
    The piping, it’s better then art.
    What do you use for a bender?
    “I haven’t failed. I’ve just found 10,000 ways that won’t work.” - Thomas Edison
    “It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
  4. Likes Metalman0880 liked this post.
  5. #3
    Caledonia WI
    Rems curvo.
    Quote Originally Posted by rider77 View Post
  6. #4
    Jul 2018
    Wisconsin
    Looks great. Is that two air eliminators? Is that CSST or did you bend black pipe? Where is your expansion tank, I would imagine off the bottom of the spirovent?
  7. #5
    Feb 2015
    Ohio
    That is art right there. I hope your customers realize the workmanship they're getting with you. I also hope your sparky finishes it off with the same amount of care. Should've just grabbed some conduit and bent and secured it so it would all be uniform.
    "If common sense was so common, everyone would have it."
  8. #6
    Caledonia WI
    The first one is a magnetic dirt separator, the tank and feeder are out of the picture and it's black pipe.
  9. #7
    Feb 2011
    Georgia
    Quote Originally Posted by billg View Post
    How in the world do you bend black iron. Is that soft copper? And if it is how do you get it so straight?
  10. #8
    Caledonia WI
    Type L copper, I use a Rems curvo bender.
    Quote Originally Posted by chrisevansac View Post
  11. #9
    Jun 2011
    NE Ohio
    beautiful work ... did you used to be a master electrician ? are you proficient at bending the tubing as to where it is a real time saver not having to solder the fittings or do you miss once in awhile ? even if you did miss once in awhile you still are probably saving a lot of time and money not soldering in fittings ... I have a few hand benders for emt but never took the time to understand the markings and where to start the bend so I end up with a bit of scrap emt when I am done ... keep up the good work very nice
  12. #10
    Oct 2011
    Culver, Oregon (Central OR)
    I havent touched a boiler in 10 years. Help me to understand the setup. Obviously the piping looks great but I am trying to wrap my head around the multiple pumps, etc.
  13. #11
    Oct 2002
    Primary Secondary pumping
    Quote Originally Posted by Adlerberts-Protege View Post
    This is what we call primary/secondary pumping. Pump below the boiler is the primary boiler pump pulling cooler water off the radiation loop circuit, heating it up and putting it back into the radiation loop. Boiler guaranteed to always have good GPM flow through heat X. Other pump is the radiation loop pump "secondary" which only job is to deliver the BTU's being put on the bus to their final destination "radiators".
    Greg Hunsicker
    www.mcelroys.com
  14. #12
    Oct 2011
    Quote Originally Posted by ghunsicker View Post
    Ok. Ya I am familiar. Just didn't look like it was piped conventionally. Maybe all of those beautiful bends are messing with what I see, lol.
  15. #13
    Bending pipe is about like bending conduit. Real conduit - not EMT.
    PHM
    PHM
    The conventional view serves to protect us from the painful job of Thinking
  16. Likes chrisevansac liked this post.
  17. #14
    Jun 2012
    Northern NV
    REMS tools, good German stuff. Used to rep them and sold the heck out of their hand held threaders and water soluble cutting oil in a spray bomb.
  18. #15
    Feb 2015
    Northeast Ohio
    Hope you guys keep an air vent on your trucks haha
    God Bless,
    Tony
  19. #16
    Jul 2018
    Wisconsin
    I Dont think he will have a air problem. What make you think that?
  20. #17
    Feb 2015
    Northeast Ohio
    Inside the unit they have an air vent, they are notrious for leaking.
    Nothing to do with your install it looks great!
  21. #18
    May 2018
    St.Petersburg
    Wow beautiful work !
  22. #19
    Caledonia WI
    I close them after a couple of weeks of running, by then you shouldn't need them anymore.
    Quote Originally Posted by NortheastTech View Post
  23. #20
    May 2019
    Arts work, never see a bended NG black iron pipe
