Results 1 to 20 of 54
Thread: iManifold APP 2.0 RELEASING NOVEMBER 15!
    Dec 2016
    Ellicottville NY
    Hi, everyone Here at North Park weve been working like mad on our new iManifold App 2.0, and we are really excited!
    The new app now has over 35 new features and growing. We have a series of webinars starting Friday, Nov. 9th where you can learn the details and see it in full operation. https://imanifold.com/resources/virtual-training/
    We look forward to seeing you there.
    All the best,
    Bill
    Jul 2018
    Hello everyone, we have a webinar tonight at 6 pm Eastern that you will want to join if you are interested in learning more about some of the 35 + features of iManifold Pro+ driven by iManifold App 2.0 set to release tomorrow! You can go to the iManifold facebook page to follow the live stream or get the link to the webinar from there! Theresa
    Oct 2014
    Columbus, Ohio
    So I just got this update, and I'm very annoyed that I have to register an account just to use the tools I paid for. I want an option to revert back to the old version that does not require a login.
    Dec 2016
    Ellicottville NY
    Quote Originally Posted by rjk_cmh View Post
    Hello, sorry you have to go through this but you only have to do it one time. We had to do this for better data security and protection of your hardware. Next time when you open the app it will log in automatically.
    Jun 2011
    michigan
    What happens if you don't have a data connection when it tries to log in?
  6. Likes rjk_cmh liked this post.
  7. #6
    Dec 2016
    Ellicottville NY
    Quote Originally Posted by kra2y View Post
    You just need a data connection for the first time you login. After that the app will open and operate without a data connection.
  8. #7
    Dec 2016
    Ellicottville NY
    We would like to hear your feedback! How do you like the tutorial functionality? When you select View Gage from the home page, do you like it? If you do like it, where else do you think we should have the tutorials within the App?
    With our new architecture we should be able to make changes in a short time so please give us your in-put.
    Thank you, everyone!
  9. #8
    Jun 2011
    michigan
    So 4 things so far that I don't like or i aint doing right? I downloaded app on my extra phone in case I didn't like the new version and could go back.
    1st problem. If I power on more than 2 pressure probes and go into map probes it will tell me that 2 probes are mapped the same. But I can't set the extra probe as just a repeater probe and it won't let me back out of map probes until I power off the extra pressure probe. If I don't go into map probes I'm ok. But If I need to change any mappings I can't have a pressure probe as a repeater. There should be an option to map it as repeater.
    2. We no longer have trending? I used to trend return air to prove a system was heating or cooling even if was only 0.25 degree change in 30 minutes I could see it and show customers.
    I also used trending to do nitrogen pressure tests and let is sit and go do something else and come back and could check through the trending to see my pressures and if there was a consistent drop or not over time.
    3. We no longer can see t1 t2 t3 T4 on the iConnect without mapping them to something?
    I use the t1 t2t3 t4 temps alot on boilers to see water temps supply and return and can't no longer? Also preferred to see the trending of them over time.
    4. This is a big issue now.
    I have 4 pressure probes because I have a lot of rtu units I work on with 2 compressors so I would put the 2 air probes in and connect all 4 pressure probes up. And switch back and fourth between them on the home screen to watch my pressures of both stages. Now I have to pay for cloud services to use my probes as I have for 3 years? I've spent over $2000 on everything and it appears they have lost alot of there function now? Adding features and charging is one thing but removing function and charging to get it back is another. I hope I'm wrong on this one.
  10. #9
    Dec 2016
    Ellicottville NY
    Hello Kra2y, These are all good inputs and questions. We really appreciate your detailed feedback!!!
    Sometimes some details get overlooked and we'll fix it ASAP.
    1)We will address this quickly and fix this ASAP. By the way, are you an apple or android user? The reason I ask is apple will take a bit longer to appear in the store.
    2) We agree and are working on an improvement for this feature. What measurements are the most common that you would like to see in trending?
    3) Thanks for explaining this and we'll get you mapping for T1, T2,T3,T4.
    4) Yes and this is linked to the 1st problem that you pointed out. We'll get his feature up and running in next update 2.0.3 which should roll out today for Android and tomorrow for Apple.
    Thanks again!!!
  11. #10
    Jun 2011
    michigan
    I am on Android
  12. #11
    Jun 2011
    michigan
    2/ Trending. I would think anything that can be measured should be able to be trended, like superheat, subcooling, temps, pressures, etc. I also used trending to watch walk in coolers and freezers box temps. I would setup trending to watch a thermostat operation to see on and off points.
    3/active temps. I used to use the active temps without actually mapping them. Currently can't see active temps or pressures without mapping it to something or going into probe management to see it.
    1/ I would think being able to switch back and forth between active pressure probes is fair. Don't need to see them all at once on the screen. Basicly like it was would be great honestly with switching views of pressure probes for multiple stages. I think in terms of mapping should have an option of no mapping in cases of multiple pressure probes or multiple air probes or option of repeater would suffice I would think. After all they are built to be repeaters as well 😊.
  13. #12
    Dec 2016
    Ellicottville NY
    Thanks for your response, all good points.
    You will soon see these features in the new app. Thanks again
  14. #13
    Jun 2011
    michigan
    Something else I would like to see.
    1/
    i would prefer the App to automatically try to connect to imanifold on opening the app, or an option to toggle that on or off since I would think most people with the app have the tools.or automatically look for imanifold after selecting view Guages.
    2/
    An even bigger thing would be a way in the app to turn off all probes and the imanifold /iconnect within the app with one toggle.
    Used to at least be able to power down the imanifold from within the old app.
    Its a little tedious to turn off all the probes when you have to hold the power button on each probe for a few seconds when I have 4 to 8 probes on plus imanifold.
    3/
    Being able to see signal strength would be huge, like the new fieldpiece probes do. to know if I should power on a repeater or not. Sometimes I have to guess if I'm going to have signal issues or turn on repeater. I try not to use the repeater unless I have to save batteries which die fast.
    4/
    I find it wierd I can't use my back button on my phone to go back and have to use the back button in the app. But I suppose I will get used to it.
    Just some things I thought of
  15. #14
    Dec 2016
    Ellicottville NY
    1/
    2/
    3/
    4/
    Good morning, thanks for the feedback. I'll review with the team and come back to you after. Have a good one!
  16. #15
    Dec 2016
    Ellicottville NY
    Hello Kra2y, Our answers below. thanks!
    i would prefer the App to automatically try to connect to imanifold on opening the app, or an option to toggle that on or off since I would think most people with the app have the tools.or automatically look for imanifold after selecting view Guages. We agree and will come up with a solution.
    Used to at least be able to power down the imanifold from within the old app. Its a little tedious to turn off all the probes when you have to hold the power button on each probe for a few seconds when I have 4 to 8 probes on plus imanifold Yes we agree, this new feature that you have requested will be available in our next update.
    Being able to see signal strength would be huge, like the new fieldpiece probes do. to know if I should power on a repeater or not. Sometimes I have to guess if I'm going to have signal issues or turn on repeater. I try not to use the repeater unless I have to save batteries which die fast. We do have that as indicated by the red, yellow and green dots on the left side of probes in probe mapping.
    I find it wierd I can't use my back button on my phone to go back and have to use the back button in the app. But I suppose I will get used to it. ​This was created because we have to make this same UI for both Apple and Android. Apple does not have a back button......
    Thank you again for your input!
    Bill
  17. #16
    Dec 2016
    Ellicottville NY
    Good day all, We released an update last night and its in the Android play Store, the Apple store will take a few more hours. Please give us your input.
    Best, Bill
  18. #17
    Jun 2011
    michigan
    Thank you for listening to our feedback. I will update and check out the features. Thanks
  19. #18
    Nov 2018
    Not to happy with this release
    So I updated days ago, I put it on my IPhone XS Max.
    Either this app locks up all the time or the layout for the screen is off.
    Many time I have to close the app and relaunch it just to get into it. The refrigerant selector is off by a button width.
    When I go in and set up the profile to refrigeration and set the evap and condenser profile it wont save or load my settings.
    How do you clear the profile once its loaded? Cant find how to clear it
    Also do I have to pay now to run multiple Evaps and or condensers ?
  20. #19
    Dec 2016
    Ellicottville NY
    Quote Originally Posted by Ajhvac73 View Post
    When I go in and set up the profile to refrigeration and set the evap and condenser profile it won’t save or load my settings.
    How do you clear the profile once it’s loaded? Cant find how to clear it
    Hello, Are you an android user or Apple? An Apple update should be in the store today while Android is now there. The update should solve most of the issues you have mentioned other than the screen lock up, we have not had that reported as of yet. We are on version 2.0,2. Please let us know your findings.
    Thank you for the feedback!
    Best, Bill
  21. #20
    Nov 2018
    Thanks Bill as soon as its available Ill give it a shot. Ill respond back with everything I listed up above. If I find anything else or have any ideas on the app Ill let you know.
    Thank you for the quick response and the new update.
Tags for this Thread
