Thread: Johnson Controls VSD Series II Micro Drive Issue
    Connecticut
    I replaced some 230v 3ph 7.5 hp VFD's on some AAON RTU's today. Everything went well and the RTU's are running fine but when I kill the disconnect and restore power, the VFD doesn't start even though my run contact on the drive is made. If I disconnect the wire and reconnect it, the VFD ramps normally. Any ideas? TIA.
    Feb 2014
    San Diego, CA
    Auto Reset
    Quote Originally Posted by The Reaper View Post
    Check your automatic reset parameters. P2.8.2.1 to 13 1-5 set up the AR function and 6-10 let you deside which faults you want to allow to reset automatically. On my drives I usually enable AR for all faults because there isn't much downside on our equipment.
    Connecticut
    Thanks Bill. I'll give that a try.
