Thread: Coldspot through the wall air conditioner stopped blowing cold air
    May 2018
    I have an old Sears wall unit (Coldspot, 13k btu, model#: 106 741390, S/N: E40748878, Refrigerant 22) that had been working fine until recently. Everything else seems to be working except it stopped blowing cold air. (I know I can get a new one but before I do I'd like to understand what's likely to be wrong with itName:  Outside right.jpg
Size:  174.1 KBName:  Outside left.jpg
Size:  167.0 KBName:  Outside front.jpg
Size:  136.4 KBName:  Inside front.jpg
Size:  90.4 KB.) Could it be that the refrigerant needs replacing? If so, how?
    Mar 2013
    East Concord, NY
    it's pretty beat.
    refrigerant is replaced through access ports a tech uses with his temperature and pressure gauges. Refrigerant is not a consumable, so if you have a leak (and you may not), replacing the unit is the best option.
    Nest is POO!!
    Poodle Head Mikey's Avatar
    Poodle Head Mikey is offline Membership Chair/ARP Committee / Professional Member*
    I try to stay as far away from myself as I can.
    Generally speaking; a refrigerant related problem tends to happen slowly; performance degrading over time. An electrical related problem tends to have suddenly. That is; all at once the system stops performing.
    It's all pure speculation for me at this far-away distance but the above is generally acurate.
    PHM
    Quote Originally Posted by HVACJPao View Post
    PHM
    When faced with the choice between changing one's mind, and proving that there is no need to do so, most tend to get busy on the proof.
    May 2018
    Thanks, Guys. I turned it on again and didn't hear the compressor kicking in. Any recommendations on a replacement? This is a single-person master bedroom (13' x 11' and change) pretty packed with furniture. I'd like one that can turn on and off at a set temperature and relatively quiet.
    Haier makes a nice line of 'window units'. Pretty quiet. Somewhat pricey for the good ones - but you get what you pay for I think.
    PHM
    PHM
  6. Likes HVAC_Marc liked this post.
  7. #6
    Mar 2013
    East Concord, NY
    Ive ALWAYS had a good experience with Haier products. A one ton unit is kind of big. make sure that it fits the wall hole before purchase.
    Nest is POO!!
Quick Reply Quick Reply
Register Now
Log-in
Tags for this Thread
  • You may post new threads
  • You may post replies
