Thread: Need some help!! Replacement T-stat
    I need to replace a bunch of Mammoth T-stats with some other manufacturer but can't seem to find one with a "fault light".
    My Mammoth stats wiring designation:
    C 24 Volt Common
    X Fault LED
    G Fan
    Y1 Compressor
    R 24 Volt Power
    O Reversing Valve
    P 2hr Override
    N Night Setback
    P and N I can do without as we don't use either feature.
    The Water Furnace TA32W02 shows to have a fault light. Will it work and be a good replacement to the ancient Mammoth T-stat??
    Thanks all for any help you might provide me!!!
    Feb 2016
    SE Michigan
    Did you ever find a solution?
    Quote Originally Posted by LakesCo View Post
    Just went with a White-Rogers model 1F97-1277. Using the room occupants as the "trouble light" now....... So far so good!!
