Results 1 to 17 of 17
Thread: Interesting service call on a smelly furnace today!
    Apr 2010
    Central Coast, CA
    I got called out into the valley to look at a furnace that was throwing up an error code for a flue proving switch/pressure switch error. The switch tested out fine but would intermittently open and throw the furnace into an error code and sometimes a lockout. I found a small crack in the pressure switch tubing so I replaced the tubing and the error went away. "Great" I thought. Problem solved.
    Three days later they called back with the same problem. I went back out and was getting the same pressure error again. I decided to pull the inducer motor off to check for anything and I found this. BTW, it smelled terrible. It looked like he chewed on the fan blades inside the inducer for some period of time before it came on while he was in there! Once I dumped his nasty little ass out of there the thing worked great again!
  2. Likes armandomartinez liked this post.
  3. #2
    I don't see why that needs posting. you act like a service call with a dead animal has never been seen before. oh maybe it's your dinner.
  4. #3
    Apr 2010
    Central Coast, CA
    My dinner? Please. My three year old nephew can be funnier and more inflammatory then that and he can barely talk.
  5. Likes lions_lair, Pajal liked this post.
  6. #4
    Mar 2014
    Charlotte, nc
    Fk it dump some hot sauce on that bad boy lol
  7. #5
    Mar 2014
    Charlotte, nc
    On a side note I had a rat get shredded in the blower wheel before...was disgusting
  8. #6
    Aug 2009
    Beatrice, NE
    So the inducer wheel is now out of balance and you just put it back together and let it run?
  9. #7
    Western Wa.
    If people didn't post up stupid stuff they ran into everyday this forum would just be a bunch of rednecks flapping their gums in the ARP section. Why so angry?
    UA Proud
    "Phfft! Facts. You can use them to prove anything." Homer Simpson
  10. Likes STEVEusaPA, HVAC_Marc, Pajal, DavidCC liked this post.
  11. #8
    Mar 2013
    Billington Heights, NY
    at least you didnt have maggots running around like the last one i did. i even got some juice on me when i pulled the lower inducer drain hose.
  12. Likes buttwheat liked this post.
  13. #9
    Jan 2012
    Broomall, PA
    I guess the take away is never assume anything, and taking shortcuts may equal call backs. Anything with venting/pressure switches I always check the vent-pull the flue pipe, check the chimney (when possible) with a mirror & full combustion test including draft.
    At least it was dead and you didn't 'release the Crackin'.
    If I do a job in 30 minutes it's because I spent 30 years learning how to do that in 30 minutes. You owe me for the years, not the minutes.
  14. #10
    At The Point Of No Return
    Last one I had was a squirrel with the magots. I put a coarse wire mesh over the exaust cause they wanted something done about it. Couple of days later we got a big dump of heavy wet snow just barely freezing so the heat never came on during the snow and plugged the vent. Had to go back to take off the wire mesh after the snow melted on the roof a few days after that.
  15. #11
    Desert Southwest
    Is that a Pack Rat? Cool picture.
    If you can't fix it with JB Weld, Duct Tape, and Ty Wire it has to be replaced.
    No good deed goes unpunished.
    If you want to take off friday to go fishing then make sure you train your helper right.
  16. #12
    State College, PA
    Quote Originally Posted by desert guy View Post
    No. Inducer Rat.
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://hvac-talk.com/aop
  17. #13
    May 2017
    Weirdest service call I've ever had was when I removed a duct and there was a live catfish in there. I was a vacant apartment to so I don't know how he got in there and how he was still alive.
  18. #14
    Athens, Ohio
    Quote Originally Posted by TedBundo View Post
    Easy. Catfishnado.
    https://www.hvac20.com/ High efficiency equipment alone does not provide home comfort and efficiency. HVAC2.0 is a process for finding the real needs of the house and the occupants. Offer the customer a menu of work to address their problems and give them a probability of success.
    Find contractors with specialized training in combustion analysis, residential system performance, air flow, and duct optimization https://www.myhomecomfort.org/
    Site member map HERE!
  19. #15
    May 2017
    Quote Originally Posted by kdean1 View Post
    Easy. Catfishnado.
    Dude that makes total sense. Totes mcgotes thanks man
  20. #16
    Feb 2019
    Cape Cod Massachusetts
    I once found burner tubes clogged by spider nest with the live spider crawling out. The furnace worked nicely after the spider was evicted and the tubes cleared.
  21. #17
    Sep 2009
    Marietta, GA
    Ah, man..yuck.. I would told the customer they need a new inducer and toss the old one in the trash.
