+ Reply to Thread
Results 1 to 12 of 12
Thread: Phase to ground v Phase to Phase voltage on 208/230V 3ø at disconnect
    Mar 2016
    Pahrump, NV
    What voltages should you expect on a 208/230V 3ø?
    I am working on a walk in freezer at a KFC. While I was on the roof, I kept hearing a compressor for one of the coolers try to start. It would start, run about 2 seconds and then stop.
    The KFC manager told me that they have had several breakers trip in the last week.
    So, I checked the voltage into the disconnect for the cooler condenser that was short cycling.
    I was only using a Fluke T5 voltage tester at the time.
    Phase to ground: 121/122/121
    Phase to phase: 213/211/213
    I would have expected to have phase to phase readings more like 244V.
    Any thoughts for me?
    It's an upside down world we live in.
    edmonds wa
    Amp draw over what it is rated at, voltage drop off when starting, loose wiring to breakers. Could be many issues
    UA Local 32 retired as of Jan 2020
    Jan 2010
    On a Delta Wye service you'll most likely see closer to 208 voltage.
    Around here 230 voltage comes from a Delta service.
    Mar 2016
    Pahrump, NV
    I'll need to check with Valley Electric to find out if it is Delta wye service.
    Jan 2010
    Just look at the service coming in to the building. 3 wire w/ ground or 4 wire w/ground. If the latter the forth wire will be the neutral.
    Mar 2013
    did you amp compressor and gauge up to system ?
    Mar 2016
    Pahrump, NV
    Quote Originally Posted by buford View Post
    I had the disconnect off to the unit while testing. I did find several wire nuts on the unit I was working with corroded conductors underneath. Many nuts were facing down allowing condensation to accumulate in the nuts.
    Here is a picture of the disconnect interior of the one I was working on. Notice the red nut that was touching the panel front.
    Jun 2012
    Northern NV
    If all three lines to ground/neutral are in the 120V range, then you have a "Y" service coming in and the phase to phase voltage should be 208VAV or within 10%... Your seems kinda high, so I doubt that it would be an issue starting a 3phase compressor as higher V is less A
    Jun 2012
    Northern NV
    If it were a Delta service, the phase to phase would be in the neighborhood o 240VAC and two of the line to neutrals would be 120VAV and one "wild leg" would be about 208VAC. Delta generally found in more industrial applications with a lot of 3 phase loads and not much in the 120V...
    Mar 2016
    Pahrump, NV
    Quote Originally Posted by northeastbeast View Post
    No, I didn't have authorization to work on that unit.
    Mar 2016
    Pahrump, NV
    Three phase Wye makes a lot of sense now. Looking at the picture of the disconnect that I posted, the white wires under the broken wire nut appear to be the neutral.
    Mar 2016
    Pahrump, NV
    Quote Originally Posted by Juan Madera View Post
    Almost all of our voltages here are on the high side. We regularly measure 248V on 240V single phase residential circuits. In a couple of sections of town we get 254V readings.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
