Results 1 to 13 of 13
Thread: CONDENSER MOTOR BRACKET SPREADER
    Jun 2013
    Central Florida
    Makes spreading brackets for removing and installing condenser fan motors much easier. For vertical or horizontal.
    5/16" bolt, square nut and acorn nut; all stainless steel purchased at Lowes. Only a couple of dollars makes several.
    JUST A LITTLE CLOSER AND THE LITTER BOX IS ALL MINE!
  2. Likes SkullMonkey, HVAC_Marc, Wheelbaron, coopbro liked this post.
  3. #2
    Jan 2010
    Those belly band brackets sure can be problematic in the field. Only if God had provided us with a third arm could it be any easier.
  4. #3
    Aug 2009
    Beatrice, NE
    I usually just stick the end of my 12" cresent wrench in there and twist, it spreads it far enough and has enough back pressure to hold it in place. No it's not adjustable but I don't have to crank on it to get it opened or closed, just a quick twist.
  5. #4
    Jun 2013
    Central Florida
    Quote Originally Posted by BNME8EZ View Post
    I used to do that, but it's not so easy to remove a 1.5
    hp 3ph motor hunched over a 200 ton Trane chiller with one hand while your other hand tries to pry the bracket open. Too many dropped tools and motors, and scraped skin. This saves me a BUNCH of aggravation; I made one for all the guys in our shop; they get used a lot
  6. Likes mccann liked this post.
  7. #5
    Oct 2016
    kentucky
    smart idea think i'm going to have to me one myself
  8. #6
    Oct 2016
    kentucky
    smart idea think i'm going to have to make one myself
  9. #7
    Nov 2011
    CO
    Good idea. Upgrade it by using a wing nut instead of a bolt. Then you don't need a tool to turn it.
  10. #8
    Jun 2013
    Central Florida
    Quote Originally Posted by 71CHOPS View Post
    I believe you mean a wing BOLT? But then, you're going to need a wrench to tighten the new motor in place anyway, aren't you?
  11. #9
    Nov 2011
    CO
    one less thing to drop! LOL!
  12. #10
    Jun 2016
    Crossett, Ar
    Good idea i usually end up wedging my pliers in there.
  13. #11
    Jun 2018
    Bay saint louis ms
    thats a great Idea
  14. #12
    Jan 2014
    New England
    Patent it and come up with a catchy name for it and trademark the name
    In all seriousness that’s a good idea...
  15. #13
    Jun 2018
    Bay saint louis ms
    It’s always a fight especially when you are by yourself
