Results 1 to 18 of 18
Thread: 4 in 1 Motors?
    Jun 2007
    So Cal
    4 in 1 Motors?
    Needed a 1/3 hp condenser fan motor cpl days ago, supply house didnt have it in the right mount, so they gave me 4 in 1 motor. So I was expecting to see lots of wires and a diagram to configure it to what I needed. But just 4 wires (2 for cap and two power leads) Course the homeowner was watching over me so I was kind of embarrassed when I didn't know what to so.. Called the supply house but of course they couldnt help, gave me a # for tech support, called and just got VM. So I just plugged it in a took off. Can someone tell me what the deal is w those motors??
    2 wires for your power and 2 wires for capacitor. Lot of times OEM is 3 wire but no biggie to use the 4 wire. Often there's a diagram on the side of the motor.
  3. Likes doug1111 liked this post.
  4. #3
    Mar 2016
    Pahrump, NV
    What brand were you using? The ones I have seen have multiple HP leads.
    It's an upside down world we live in.
  5. #4
    in a house, Appomattox, Va.
    I see them w/4 wires for 4 or 3 wire motors. the tan and tan/white stripe are connected internall to the motor. You can do separate cap w/the two tans, or dual cap and wire nut the white or white/tan wire.
    Some have screws on the side of motor, that's for a rheem setup.
    Col 3:23
  6. #5
    May 2016
    GA
    Most multi-hp condenser motors have 5 wires.
    Brown & Brown with white stripe = capacitor
    White = common(hot leg)
    Red or Black depending on hp being used = hot leg
    Cap off the unused red or black
    That's my experience anyway with multi-hp motors
  7. #6
    Jul 2016
    Did that condensor motor use a different sized capacitors for the multi hp? I have seen some 5 wires that require a different sized capacitor depending on the hp used.
  8. Likes doug1111 liked this post.
  9. #7
    Mar 2015
    Medford, N.Y.
    I thought that the diff caps was for diff voltages,208 vs 240vac?
  10. Likes doug1111 liked this post.
  11. #8
    Aug 2011
    Quote Originally Posted by TechmanTerry View Post
    Yes on some diff cap diff volts. & Some diff cap diff HP. & some high & low speeds. You get a lot of options for little $-- real cheap @ Goodman dist!
  12. #9
    Mar 2015
    Medford, N.Y.
    doug, I guess I have to get out in the world a little more. The Rescue motors that I use are diff cap/diff volt. TKS!
    rchris, what brand did you use?
  13. #10
    Aug 2011
    Suppliers are always running out of condenser fan motors. Good parts was the last brand I used. Worked out okay.
  14. #11
    May 2016
    GA
Size:  61.3 KBName:  Motor.jpg
  15. #12
    Mar 2015
    Medford, N.Y.
    That motor in the photo is like my Rescue motors, 1 size cap for 208v and a diff cap for 230v.
  16. #13
    Nov 2011
    St. Louis
    Maybe what he was asking was how to select the needed HP if it had two wires for the cap and two wires for power. I've never seen that, most having five wires; two cap, red and black for HP selection and white for the other leg.
    Is the Religious Right to blame for Christianity's decline?
    They argued that, as the Religious Right became increasingly visible and militant, it became associated with Christianity itself. And if being a Christian meant being associated with the likes of Jerry Falwell, many people—especially political moderates and liberals—decided to simply stop identifying as Christians altogether.
    http://www.theamericanconservative.c...nitys-decline/
  17. #14
    Mar 2015
    Medford, N.Y.
    The OP has a 1 speed motor, single HP. How about the motor spec's there Mr.OP.
  18. #15
    Looks to me like a only really has 2 hp selections - 1/3 & 1/4 are the same tap and 1/5 & 1/6 are the same tap.
    Also looks like it has 5 wife's, 2 for cap, neutral/L2 and either red or black for HP/L1.
  19. #16
    Mar 2016
    Pahrump, NV
    I tried doing some research on this.
    It appears that the windings are more robust on the multi-HP motors. Although two HP ratings use the same tap, they can handle a greater variance in amps created by the load while maintaining close to the same RPM's without overheating.
  20. #17
    Jun 2007
    So Cal
    Yeah I was expecting to see something like this.. But again: only four wires, no diagram, no options. Still confused.
  21. #18
    Quote Originally Posted by rChris View Post
    What is the motor info.
    We can only guess without it.
