First post in here. Ran into a carrier rooftop today with a fan cycling switch. Well who ever installed let the wire rub and short to the suction line causing a leak. Repaired leak and started system up. Condensor fan never came on ohmed motor ohmed out fine. Had 240v to it. Could the motor have a burnt wire or some sorts inside to where the motor would ohm fine and not run?
