+ Reply to Thread
Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 91
Thread: York RTU heating Ignition control failure during AC, unit locks out??
  1. #61
    Nov 2018
    Could you please email me a copy I have one now that’s stumping me. All limits and contactor seem ok.
  2. #62
    Southeastern Pa
    Quote Originally Posted by Robsmiley1 View Post
    Make sure you have a valid email address that is visible in your "about me" section of your profile, so you can receive an email from SLC.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  3. #63
    Sep 2019
    Not sure if this individuals issue was resolved, but I ran across this same 9 flash code on a gas pack during cooling, and found I was only receiving 11 volts on the top left terminal (yellow wire) labeled limit on main board. Traced to high limit corroded connection, cut stripped and recrimpped new female connector, wire brushed terminal, 26vac on board now but ordered new limit switch regardless. I guess yorks want to know they're limits are good before you call for heat, makes sense =].
  4. #64
    Sep 2019
    [QUOTE=FixitFelix;25778567]Not sure if this individuals issue was resolved, but I ran across this same 9 flash code on a gas pack during cooling, and found I was only receiving 11 volts on the top left terminal (yellow wire) labeled limit on main board. Traced to high limit corroded connection, cut stripped and recrimpped new female connector, wire brushed terminal, 26vac on board now but ordered new limit switch regardless. I guess yorks want to know they're limits are good before you call for heat, makes sense =].
    [If you ain't have time to do it right, then you must have the time to do it twice. 😊
  5. #65
    Southeastern Pa
    What doesn't make sense is that the code nine will lockout cooling.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  6. #66
    Sep 2019
    According to York they stated 24 volts runs through the heat limit and back to the board where it monitors it regardless of heat call or cooling. I found it weird as well. But issue went away, will update upon switch replacement if it happened again prior to returning.
  7. #67
    Southeastern Pa
    Quote Originally Posted by FixitFelix View Post
    ....and that is what you call a bad design.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  8. #68
    Sep 2019
    Joliet, Il.
    May I have a copy of the manual as well?
  9. #69
    Sep 2019
    Don’t have one I’ll try get a schematic. Haven’t been back, another technician replaced the switch, unit hasn’t been down since, been over a month.
  10. #70
    Nov 2019
    Access to manual?
    I can not access this manual. I am dealing with a multiple call back on a York RTU which is erroneously engaging the heat cycle.. and full heat cycle in which valve opens and igniter is lighting?
  11. #71
    Southeastern Pa
    What have you tested so far?
    What were the results?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  12. #72
    Southeastern Pa
    Quote Originally Posted by Drae K. Osburn View Post
    One more thing.
    Please do not post your need in someone else's thread.
    Next time, start your own. Give the model, serial, etc, and state your issue.
    Thanks.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  13. #73
    Jul 2020
    Any chance the troubleshooting guide is still available?
  14. #74
    Salt Lake City/Tooele
    I do not get reminders or alerts that this thread is still being accessed and people are requesting a copy of my troubleshooting manual. The original link DOES work, but you must be a PRO member to access it. From here on out people just need to work on getting there PRO membership and they can access the link. To learn how to get membership go to this link:
    https://hvac-talk.com/vbb/showthread...nal-Membership
    It is not a hard process and invaluable to become a PRO as to access all the resources that can assist you in your career. Hope to see you all there.
    I do have some Youtube stuff about the York Simplicity software and how to use it, you may not use the software but through out those videos I do touch upon 9 blink issues.
    Cheers,
    SLCTECH
  15. #75
    Dec 2020
    Hi SLCtech, could it be possible to have that manual? Ran into this issue today on an heat pump rooftop unit.
    Could use some help.
    Thank you!
  16. #76
    Southeastern Pa
    Looks like this guy was a one post wonder. No additional info, no response. Oh, well.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  17. #77
    Quote Originally Posted by timebuilder View Post
    TB....I noticed I missed a text from you some time back, I was in AZ visiting the in-laws and was out of cell service for a week (it was pure serenity) and once back into range was obliterated by awaiting texts and voice messages. So I apologize your text was missed. I figure you got your York issue resolved. In any case if we do not talk or text, you have your self a wonderful Christmas my friend!
  18. #78
    Quote Originally Posted by pao06800 View Post
    Thank you!
    Feeling festive, sooooo you have mail. If your profile is accurate, you should apply for PRO, you would be an asset to the community.
  19. #79
    Jun 2022
    Argentina
    Hi, could you please email me the troubleshoot guide I do not have access to it. Please
  20. #80
    May 2014
    Bay Area California
    It would be best if you interacted for a bit. Because we really know nothing about you. By the way, there is tons to learn here.
    Quote Originally Posted by Gquenan View Post
    I do a triple evac with nitro to remove non condensables.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
