Originally Posted by
kdean1
I've never seen a double flare before. Thanks for posting the pictures.
X1
Forgot the nut BB
Do it again
Post Likes - 1 Likes, 0 Dislikes
Seriously though is there a need to ream and file with the double flare? Looks like the outside of the tubing needs the attention. That one that is finished doesn't look like the surface was hardly smoothed and looks real rough
You have to push on a square edge to get a square flare.
itsiceman
It's not what you're capable of doing that defines you, it's what you do on a daily basis.
itsiceman
That was just a scrap in the bottom of a bucket. I did not ream it or clean the pipe at all. I do not file the end on a double flare, but I do ream it, maybe more out of habit than anything.
My understanding double flares were for stainless steel brake lines to decrease the possibility of vibration fractures. But what ever works for ya. BTW A step bit reams nice.
We are here on Earth to fart around ......Kurt Vonnegut
You can be anything you want......As long as you don't suck at it.
USAF 98 Bomb Wing 1960-66 SMW Lu49
On Copeland condensing units they used to double flare suction line, don't know if they still do. But, interestingly enough, not the discharge line.
hvacker
Found it!
Member of the "Work Exchange Program"
"Will work for knowledge"
"Everyone is a genius. But if you judge a fish on its ability to climb a tree, it will live its whole life believing that it is stupid"
A Einstein
BBeerme
I have never in my life bought a pre made flare.
Then you probably don't work with hard copper much. I have used the pre made flares many times when working with hard copper. They have always worked good for me.
hands
Why wouldn't you just anneal it, and make your own?
I've never even seen a "pre made" flare for sale.....
A Einstein
I thought double flares were pants from the 70s!
Kidding aside, never saw a double flare before. Interesting post.
Just when I thought I knew everything,...
I remember learning to use a double flair kit back in the 80's going to tech school
Maybe if they were double flares I'd consider it. But as Kramer said, I just anneal the copper. Like when I have to bend hard drawn, I anneal it first. For bending, probably even faster to anneal. Unless the job is spec'd out for those calcium silicate pipe supports and fiberglass insulation, you need sharp 90's to fit the insulation 'fittings', so it pays to take more time to cut and fit the pipe with copper fittings then braze it up.
hands
Once in awhile I'll get through a whole day without learning something. But not very often!
River7
Yeah, it's a great little kit. I've seen all sorts of other gadgets through the years. In fact, you might say I like all of those other gadgets. Since I go behind those others to fix all of the leaks with my double flares, LOL. Easy money.
I'm just the kind of guy that finds what works, then keep doing that over and over. Sure, I'm always trying a little this or a little that to up my game. But for something so basic as a flare . . . I haven't made a regular flare in over 30 years; and haven't had a leak at a flare in that same amount of time.
If I find something better, well, we'll cross that bridge when we get there. But it has to be simple, small, cheap, and more reliable than a double flare . . . LOL !!
kamersoutdoor
Found it!
I've seen refrigeration equipment manufactures use double flares as well. Mostly on sae pressure switches. I personally use them when I'm splicing a brake line on a vehicle.
Cool.
I believe the Double Flair had to do with,
1.Steel Line.
2.PSIG.
Steel is Very easy to 'split' and,
Brake lines psig is a LOT higher than what we use,as in close to 1K depending on the application,and I have split many with a standard flaring block but,
I SEE the Point BB.
I personally have never done a Double in Refrig and,likely never will.But,
I am Irish and have Good Luck.
No matter how long you have been doing this,
Go back and reread the Basic's.You WILL Learn something.
Why is it called,an Act of GOD when IT has Nothing to do with Him?
Will of the Devil would be more appropriate IMO.Just Saying.
PSALMS, 18 & 25.
I am Tired of High Efficiency Propaganda.
mrkelly
Well then.... top of the morning to ya.....and may the road rise to meet you.....
And you too Sir.
May you be in Heaven,
A half hour before the Devil knows your Dead.
PSALMS, 18 & 25.
