+ Reply to Thread
Results 1 to 8 of 8
Thread: Dehumidification limitations
    Apr 2016
    Ottawa Canada
    There is an inherent limitation in conventional air conditioning methodology that often results in systems that cannot provide adequate dehumidification, and compensating for which only comes at a premium price. DewAir’s RH Cube completely overcomes this limitation, and in the process reduces overall system cost and energy consumption. In New State of the Art we look at the patented technology introduced in the RH Cube and how it provides independent humidity control, and dramatically reduces energy consumption.
    we need opinions visit www.dew-air.com feed us with opinions
    Madison, WI/Cape Coral, FL
    Welcome aboard. Supplemental dehumidification and fresh air ventilation are starting to catch on. We have been working on this for 20 years with limited success. Currently most major US a/c mfgrs are offering some form of dehumidification. Some better than others.
    Keep us posted on progress.
    Regards Teddy Bear
    Apr 2016
    Ottawa Canada
    need your help teddy
    Quote Originally Posted by teddy bear View Post
    Regards Teddy Bear
    you know more than other pls have a look and you will see something that will change the industry standars ,, need your opinion .. www.dew-air.com
    The RH Cube is a breakthrough cooling dehumidification system. Its unique, patented architecture straddles the gap between air conditioners and dehumidifiers. Until the advent of the game-changing RH Cube, the only way to control both the humidity and temperature was with an expensive, complex, and inefficient system that was out of reach of most customers. The RH Cube has changed all that by enabling independent control of temperature and humidity efficiently and at a very affordable price.
    Aug 2009
    Prattville, Alabama
    There's not much technical info on the unit itself.
    What cools the cooling coil?
    From the diagram, it looks as though refrigerant liquid line and suction line connections exist.
    Where is the heat that the coil absorbs rejected?
    Is this unit "grafted" into the existing refrigerant system?
    Quote Originally Posted by Dewgerry View Post
    I can not comment on the price, but some have been using the heat exchanger concept for +20 years to get the max moisture removed per KWH. The heat exchange is a solid concept. Makes the dehu big and a little pricey but well worth it. My hat is off to you if you came up with it on your own.
    Stay in touch.
    Regards Teddy Bear
    Apr 2016
    Ottawa Canada
    Quote Originally Posted by Nuclrchiller View Post
    thank you for your respond it is making me recognize that I need to clarify details
    this is typically an split type air conditioner which a newly added set of counter flow air to air heat exchanger is added .. the set of air to air heat exchager works in similariteis to a heat pipe but is very low cost and much more efficent
    through this achchitecture we are able to provide a cooling process typical like an air conditioner efficencies but its cooling process provide around 90 % dehumidification instead of the usual ??
    we are trying maintaining low cost unit since it is a a/c at the be operating cost of an conventional type a/c
    piping is the same as a a/c so is its controls ext
    they are several ways to install this .. either can be combined to a centra system or stand alone
    also got all the convinience of ducting filtering ext
    I understand that is part of a/c not an independent dehumidifier. Some dehumidifiers also use a heat exchanger to improve moisture removal compared to a/c or conventional dehumidifiers. They are in the 8-9 pints/kwh. Many dehumidifiers are in the 2-4 pints per kwh.
    With 75^F, 50%RH return, what would you expect the sensible/ratio to be with 93^ outdoor air? What is the extra fan power needed for the air flow through the heat exchanger?
    Is this a package that is being sold?
    Regards Teddy Bear
    Apr 2016
    Ottawa Canada
    Regards Teddy Bear
    thank you so much last question since I see exactely that yiu are so well informed
    yes there are dehumidifier that are that efficient but I am aiming 12000 btu dehumidier and the best one in the market is 7 pints per kw and it sell to contractors at $3 K.. What I am proposing is a unit that perform at 10. pints per kw and that will sell for 2.5 $ k
    million dollar question
    Will I be able to sell this at this cost to contractor dealers in your opinion
    more efficent , better performance .. more dehumidification at 20 % cost reduction
    keep in mind I am no longer selling a dehumidifier .. I need to sell this in the HVAC trade which they are much more agreesive ..but they also have a infinite market as compared to the dehumidification trade
    Please help me with more comments
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
