Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 67
Thread: Re-purposing refrigerant jugs?
  1. #41
    Mar 2015
    Medford, N.Y.
    I had a boss , he made "oil day tanks" out of them for use in industrial bldgs. Probably close to 50 bldgs. Boy oh boy did he get mad at me ,as, I refused to install them.
  2. Likes joejax liked this post.
  3. #42
    Feb 2016
    Florida
    Atlanta GA area
    We use them for mufflers on Experimental aircraft... Specifically gyrocopters... Subaru engines are popular...
    Cheap... and the exhaust sound is cool!
    GA-HVAC-Tech
    GA's basic rules of home heating and AC upgrades:
    *Installation is more important than the brand of equipment
    *The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
    *The value of comfort, over the long term; leave economic choices behind!
    Choose your contractor wisely!
  5. #44
    Mar 2015
    Medford, N.Y.
    joejax, I like that diagram!! But,these "day tanks" were up by the 20'ceiling, and they fed oil into 6 or so hanging oiled fired furnaces. There was an oil transfer pump at ground level that fed the "day tank" and a "over flow" return line from the ceiling mounted freon tanks. And the yo-yo boss was using 15% sil-phos to braze a brass MPT x MSAE fitting into the steel tank which according to AllState and Harris ,that makes a "brittle" joint.
  6. #45
    in a house, Appomattox, Va.
    ther's some animals I made..
    Col 3:23
  7. #46
    Jul 2012
    Bridgeton, MO, 'burb of St. Louis, Mo
    Quote Originally Posted by billygoat22 View Post
    Nice work! What are the snouts made out of?
    If thinking was easy,
    everyone would do it!
    Regarding Russian Roulette; five out of six players think it is a safe, enjoyable game!
    "And I've been banned twice. What of it? If you aren't getting banned once every 3 years, you aren't trying." Brian8383
    "it's actually 90 right now in this shaded area of satan's butthole." - HVAC_marc
    “Don't believe signature quotes.” - George Washington
  8. #47
    2 1/2" emt, some sheet metal cut in circle for end. I welded from inside and sanded smooth the outside edges. Used a punch to make the dimples.
    One I made for outside has been out for three yrs, plus. has faded, but very little rust since was careful not to have gaps water could get into. The auto primer likely helped,too.
    Col 3:23
  9. #48
    At The Point Of No Return
    The one on the right a piggy banktank?
  10. #49
    Dec 2012
    columbus, OH
    You could make a discreet piss bottle to keep on the truck for emergency's, just be be careful no one charges with it
  11. #50
    Western Wa.
    Quote Originally Posted by Core_d View Post
    That is a big piss bottle
    UA Proud
    "Phfft! Facts. You can use them to prove anything." Homer Simpson
  12. #51
    Mar 2016
    Nice Method.
  13. #52
    yes. ,ost Imade were piggy banks. kids really liked them, some would sit on like ride-on toy, or ask for change to put in pig.
    Col 3:23
  14. #53
    Southeastern Pa
    Quote Originally Posted by rcstl View Post
    R2D1????
    Close. I think it would be R12 D2.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  15. Likes ga-hvac-tech, ryan1088 liked this post.
  16. #54
    Am I the only one who got it lol
  17. #55
    Aug 2010
    As I read the actual law the prohibition is not on refilling. What is prohibited is transporting the cylinder after it has been refilled.
    What is interesting to me that originally not-refilling relied entirely on the integity of the user to ensure compliance. But as soon as reclaiming became the law-of-the-land and recycle cylinders were routinely available for sale - the user intergity was apparently deemed to be lacking as anti-fill check valves suddenly appeared on all other cylinders. <g>
    PHM
    More importantly, it prevents back washing to protect the quality of refrigerant as well as hazardous pressurization. Those two outweighs the value you'd get from reusing the empty tanks.
    If you didn't have check valve and accidentally opened high side into it, you back washed system's charge into the virgin refrigerant by the time you realize it.
  18. Likes joejax liked this post.
  19. #56
    Feb 2016
    Florida
    Hey ICanHas, stay tuned for the badass smoker I'm building!
  20. #57
    Beautiful, Philadelphia, the City of Brotherly Love!
    Made a bbq grill out of one, cut in half slightly above centerline weld bottom handles to plate steel or something to provide stability, use top for lid, add hinge if desired. Used an old commercial condenser fan blade cover as a metal rack for cooking surface and drilled a few holes for air intake.
    A buddy took 5 cylinders provided by your's truly and made a cool water gizmo out of them, one filled with water and then dumped into another, doing so caused the dumping cylinder to knock against another like a clunking bell. His wife put up with it for a summer and then it went to the scrap yard. He is on to higher grade projects these days, things people buy as art.
    “You don't get paid for the hour. You get paid for the value you bring to the hour.” Jim Rohn
  21. Likes joejax liked this post.
  22. #58
    Feb 2016
    Florida
    Man, I played hell getting these to post. Have been working on this for quite awhile, shortly after start of thread. It's all made up of junk I had laying around, except the 2 pipe fittings on the top tank and the stack on top.
    Please excuse my awful welds, I am still learning and believe I am getting better. Some think my smoke pipes are too long and will not produce enough heat, I built a small fire and had about 180 to 200 up top and awesome smoke.
    I'm still not done, need to fit the lids better, grind poop welds, secure grids, and paint.
  23. Likes ga-hvac-tech, VTP99 liked this post.
  24. #59
    Feb 2016
    Florida
    The top is an old well tank. The bottom is 3 404 jugs, I burned both in a bon fire. The bottom most is an old condenser cover piece and the jugs are cut all the way out as a rectangle, with custom vent holes and damper.
    Holding that up is pieces of a stand and a recycled ash catch. The stand is for a 55 gallon aquarium. The 2 feed tubes are from a futon frame. We have had some much needed rain so now it is a little rusty.
  25. #60
    Apr 2016
    Hi im new here..im an install tech not an owner. Anyways at the company i used to work for was a guy who used the empty 410 tanks as portable camp stoves. Cut em in half, weld hinges on the back, weld a handle on the front. The carry handles of the tank are now the feet, and then weld brackets inside to accomodate a small grate. Hook up propane to the refridgerant orfice in the bottom or use coals.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
  26. Likes joejax liked this post.
