Results 1 to 20 of 21
Thread: This is why I check every unit before startup...
    Apr 2006
    Tyler, Tx
    This is a new unit from factory. OD Fan was wired to HERM, not in picture I pulled it off before taking pic. Orange wire to compressor was wired to FAN.
    Philippians 4:13
    I can do all things in him that strengthen me.
    Apostle Paul inspired by GOD.
  2. Likes DeHeatify liked this post.
  3. #2
    Aug 2001
    Pavilion, NY
    I applaud your thourouness
  4. Likes lions_lair liked this post.
  5. #3
    Jan 2013
    florida
    yeah, but you missed all the excitement of flipping the switch and getting to say... what the fock ?
  6. #4
    Apr 2003
    Maple Grove, MN
    Are you serious? Did you actually catch that before applying power to the unit? If so, did you have this happen to you before, or are you really this thorough?
    Either way, that is a really good catch. I would never have thought to look there while doing a routine startup. Thanks for sharing.
  7. Likes DeHeatify, Artietech liked this post.
  8. #5
    the exact same reason i double check my work and double check new units before we allow them to be installed.
  9. Likes Artietech liked this post.
  10. #6
    Urbandale IA. USA
    Brand and model please.
    Never have I seen that 'from the factory'...
    Those who dance, appear insane to those who do not hear the music.
    Those who believe, appear ignorant to those who do not know God.
  11. #7
    May 2014
    Bay Area California
    That's why I let the rookie turn the power on. That way I have plausible deniability, LOL.
  12. Likes lytning, Artietech liked this post.
  13. #8
    Sep 2014
    NW Arkansas
    I see loose wires from factory all the time. Although, most techs I know would have heard it sound off and added a kickstart.
    Nice catch.
  14. Likes Artietech liked this post.
  15. #9
    Dec 2003
    Citrus County, Florida
    So much for "They are all run tested before shipping"
    Doug
  16. Likes davidj001 liked this post.
  17. #10
    Aug 2008
    Oklahoma
    Had one this summer like that. Payne unit.
    Gun Control Means Using Both Hands
  18. #11
    May 2011
    romulus, mi
    That takes away one of those lovely wtf moments .
    Sent from my LG-H811 using Tapatalk
    RTB Mechanical
    734-315-0064
    http://rtbmechanical.com
  19. #12
    you would be suprized at the mistakes i have seen from the factory from all the major brands over the years
    no one is perfect mistakes happen daily
  20. #13
    May 2014
    Bay Area California
    Had a Trane unit whose blower, sheave, and idler pulley shafts were all out of parallel. Unit installed less than a year ago. Impossible to align the three pulleys. Or even any two pulleys, for that matter. Told the customer they were SOL.
  21. #14
    Had a startup on a new Leibert unit the other day. Had starters for the fan and compressor in the unit from the factory. Both starters had the same heaters, both sized for the fan!
  22. #15
    The
    Had chilled water Leiberts some years ago, the 3 way valves were piped wrong. Had the rep . come to the job they fixed them! The Liebert tech. Hates me been to a few of my jobs that cost them! Had Data airs factory had to change 16 water regulating valves because they were not rated for the water pressure. Had 8 Trane packages two cycles, 4 were 208 and 4 were 460 same job! Trane changed 8 compressors and wiring corrected.
  23. #16
    Jan 2015
    Iowa
    Having worked in an HVAC factory very early in my career. We did do a 100% run test. The only time we ended up with something like this going out was when a machine was found to be defective during the assembly and or test process. These failed units were repaired by a repairman who was responsible for ensuring they were run tested before they pushed them down the line to the packaging and shipping guys. That was not always done. We saw the same stuff you did in the field, bad compressors, bad caps, bad fan motors, bad wire crimps, bad fans, bad brazing, etc... but all on new stuff. I have a hard time believing it is any different today
  24. #17
    May 2015
    Central IL
    i have seen a few armstrong/ ducane acs like this straight from the supply house
  25. #18
    Apr 2006
    Tyler, Tx
    Actually I was burned once when I didn't check, so yes experience taught me to be cautious. I have also worked with wierdos who "make" a problem just to see if you catch it...
    Quote Originally Posted by ammoniadog View Post
    Philippians 4:13
  26. #19
    Apr 2006
    Tyler, Tx
    Trane 13 seer, believe it was a 3.5t or 3 ton.
    4
    Quote Originally Posted by cehs View Post
    Philippians 4:13
  27. #20
    Apr 2006
    Tyler, Tx
    Yeah stuff happens. Are you telling no one here has received a condenser with zero pressure before? Or an evaporator missing the metering devise?
    Philippians 4:13
