Results 1 to 20 of 20
Thread: Homemade Gallo Gun
    Nov 2007
    Mississippi
    Homemade Gallo Gun
Size:  428.1 KBName:  ImageUploadedByTapatalk1434286630.177727.jpg
Size:  214.7 KBName:  ImageUploadedByTapatalk1434286635.666500.jpg
    I took a large schrader access fitting and fitted it to a 1 1/8" acr plug. Then added a ball valve for quick nitrogen release.
    Have wrench-Will travel
    Apr 2008
    Delray Beach, Florida
    Quote Originally Posted by socotech View Post
    Check out these fittings that you can use on the end of your hose for either nitro, CO2 or even a water hose sprayer if you have it available. https://youtu.be/K_uK_Z09keg
    Nov 2011
    St. Louis
    Cool...but my main reason for using a real Gallo is to avoid lugging a nitro tank around and up in an attic or roof.
    Is the Religious Right to blame for Christianity's decline?
    They argued that, as the Religious Right became increasingly visible and militant, it became associated with Christianity itself. And if being a Christian meant being associated with the likes of Jerry Falwell, many people—especially political moderates and liberals—decided to simply stop identifying as Christians altogether.
    http://www.theamericanconservative.c...nitys-decline/
  4. Likes Mr Bill, ruuufuhbock, David130 liked this post.
  5. #4
    Apr 2008
    Look how I use the Gallo gun in this video. I attached a refrigerant hose to the Gallo gun.
    http://youtu.be/dbYScpYD5R8
  6. #5
    Nov 2011
    St. Louis
    Quote Originally Posted by soaker View Post
    I saw that before and wish every pvc drain had one. Irritates me to no end that they don't even put a union on them most of the time.
  7. Likes David130, JayMan7 liked this post.
  8. #6
    Apr 2008
    Totally agree. It saves time and energy especially when in a 120 degree attic here in Florida. It is so cost effective that it should be a no brainer.
  9. #7
    Oct 2012
    Danville, KY
    Never seen that before, I may see about getting some to put on my truck. Probably be good for new installs.
  10. #8
    Apr 2008
    They are available at most Distributors, Model AA1
    The website is at http://allaccessdevice.com/
  11. #9
    Apr 2008
    I forgot to put up the new video that shows how it works. Here it is: http://youtu.be/l6PsgVfbkog
  12. #10
    Apr 2015
    Minnesota
    I totally agree with you, but worked for a large corporate run service company. I purchased my own Gallo Gun and continued to purchase all refills for the better part of 10 years. I had to keep the device a secret because the company didn't want us using them. The possibility of ruining carpet, drapes or furniture with careless use apparently overruled the obvious benefit for us (not blowing into condenser lines with your friggin' mouth). It's one of the best AC and condensing HH tools in the toolbox.
  13. #11
    Apr 2008
    I know. Look how it could be used on this new product.HI,
    Model AA1-FS Cleanout Device With Built-In Float Switch for A/C Drain Lines.
    Video https://youtu.be/k65g-u081tE
    Installs Inline on Primary or Plugged on Secondary Outlet of Pan.
    Website http://allaccessdevice.com/
  14. #12
    Feb 2013
    N.E. OKLAHOMA
    Why Didn't I think Of That??????
  15. #13
    Houston,Texas
    Quote Originally Posted by dobbin View Post
    We're to busy working, nice product though.
    “Experience is a hard teacher because she gives the test first, the lesson afterwards" ~ Vernon Law
    "It's what you learn after you know it all that counts." ~ John Wooden
    "When the teachers become unteachable we're all in trouble" ~ Mr. Bill
    "Remember "Pro" is only a name, it's not always a mindset determined to do everything correctly" ~ Mr. Bill
  16. #14
    Houston,Texas
    Homemade Gallo Gun
    Quote Originally Posted by StewPidasso View Post
    not blowing into condenser lines with your friggin' mouth.
    You have one heck of a blower if you can blow out a condenser line, do you blow through the suction or liquid line to clear it out.
  17. #15
    Apr 2015
    Minnesota
    Sorry... CONDENSATE line. And yes, I once called fishing line "string" too. Got the same chastising for that. My mind to mouth filter is weak. ha
  18. #16
    Dec 2014
    In my truck, driving
    Some duct tape and the hot air you bring with you.
  19. #17
    Dec 2003
    Citrus County, Florida
    Only problem using Gallo Gun is blowing the non-glued fittings apart; especially the ones the installer forgot to glue located in the walls.
    Doug
  20. #18
    Jul 2014
    Sarasota, Florida
    Quote Originally Posted by Gunslinger View Post
    I'll second that. Been there too many times. I'll stick with my 4gal 5hp shop vac and warm/hot water
  21. #19
    May 2019
    not bad, i love repurposing old stuff into new
  22. #20
    Oct 2008
    Toronto
    Nice
