Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 89
Thread: Voyager test mode box
  1. #61
    Jun 2014
    The resistance values are up higher in the thread, I tried to use 1/2 watt but wound up with some larger because that's all the store had.
  2. #62
    Aug 2013
    Dunbar, West Virginia, United States
    Yea all of the Radio Shacks have closed here. I will look at your earlier posts for vallues.
  3. #63
    Jun 2014
    Most of them are closed here as well. I picked all of this up at fry's electronics.
  4. #64
    Aug 2013
    I'll order online I say
  5. #65
    Aug 2013
    Does the wattage actually matter
  6. #66
    Jun 2014
    I just looked in a reliatel manual and it does not specify. I think I bought half watt because all the smaller ones at fry's came in larger packages that cost more.
  7. Likes coolperfect liked this post.
  8. #67
    Feb 2013
    U.S.A
    Quote Originally Posted by anthonyscardina View Post
    well Anthony id like one from you, please pm me, and let me know if you can help me out, thanks man
  9. #68
    Feb 2013
    U.S.A
    or anyone? pm me, mine I made failed me I need a better system,
  10. #69
    Jun 2014
    For whatever reason I can't PM you brazin
  11. #70
    Feb 2013
    U.S.A
    I don't think your a member? email me please, why aren't you a member, its free? join up, than you can send pm's, it says your a guest, strange...
    TEMPIRELLC@HOTMAIL.COM
  12. #71
    Feb 2013
    U.S.A
    would this work? id rather have 2 of your, just curious
    http://www.ebay.com/itm/Decade-Capac...8AAOSwcOFWbE9n
  13. #72
    Jun 2014
    That's some sort of capacitor decade box, different application
  14. #73
    Feb 2013
    U.S.A
    yea I see its nowhere close, you need 2ohm up to 35 ohm or whatever saw it listed, so can you help me out, with even one for time being?
  15. #74
    Jun 2014
    I emailed you. That box is for capacitors (microfarads) and what you need is resistors (ohms)
  16. #75
    Feb 2013
    U.S.A
    I responded Thankyou
    heres the ceramic I saw is it worth it, again if you have switches use what you have by all means don't go crazy..
    http://www.ebay.com/itm/ITT-W-German.../252000901247?
  17. #76
    Jun 2014
    That's a 9 pole switch so you'd lose one of the functions, plus that single part exceeds the cost of the whole unit I built, and would require a much larger enclosure.
  18. #77
    Feb 2013
    U.S.A
    agreed, go with what you know
  19. #78
    Jun 2014
    Okay, the first PVC enclosure prototype is done! This one is for TBrazin, custom built to order with posts that will accept standard multimeter leads. These posts are $7 per pair so they'll cost more if you want them, and do stick out about an inch as seen in the pics.
  20. #79
    Aug 2013
    Orange County CA
    Do you sell the voyager test box? I'm interested
  21. #80
    Jun 2014
    yes I have components sitting to make half a dozen or so
