+ Reply to Thread
Page 4 of 4 FirstFirst 1234
Results 61 to 80 of 80
Thread: Mercury Flame Safety Switch Obsolete
  1. #61
    Jan 2016
    Michigan
    I thought these were long gone... They've been phased out of other products a while ago.
    I agree with hearthman - Good riddance!
  2. #62
    S.E. Pa
    Rob is correct: The original gas direct vents were tested and listed under ANSI Z21.50 as vented decorative appliances-not vented room heaters. Therefore, they were never intended for continuous unsupervised operation such as off a thermostat. The new Z21.88 vented room heater std. required a 30 second pilot dropout over the old 180 second dropout. Too many cases where the unit would go out, someone would get up, walk over and hit the igniter and BOOM! Glass shrapnel everywhere.
    I would recommend using only components tested and listed by the mfr.. If the mfr. is busted, pull the unit or stick flowers in it. I've seen way too many units "fixed" with similar components only to fail or go Poof! I've investigated too many cases where people were blown across a room, knocked unconscious, blinded or burned from not playing by the book.
  3. Likes HeatenCoolair liked this post.
  4. #63
    Mar 2001
    Ilwaco, Washington
    Came across a box of them out in my shop today. Throwing stuff away, scrapping copper, and generally cleaning out the shop as I've been retired for 3 years. Gonna take these mercury switches down to the waste station the next time they have a free hazmat drop off day.
    One way to outthink people is to make them think you think. They'll think you're not really thinking what you're trying to get them to think you think...........
  5. #64
    Jan 2016
    Ontario
    Quote Originally Posted by uniservice View Post
    Uniservice,
    Are these mercury switches old ones you acquired from repairs or still new in box? They are worth money as there are none really left out there. Would you consider selling?
  6. #65
    Mar 2016
    London, ON
    Before I purchase an overpriced mercury switch (if I can find one), I want to be sure that the switch is the problem. The fireplace pilot will light but when I let the valve control out, the flame dies. If I short between the 2 poles of the switch, shouldn't the pilot flame stay burning as if it was sensing heat?
  7. #66
    Mar 2001
    Ilwaco, Washington
    Flame switches
    Quote Originally Posted by gap1927 View Post
    Uniservice,
    I know that a lot of them are new, a lot of them are different part numbers, some of them are used, but good. How about I get em all together and send them to you? Is there gonna be any problem sending mercury to you in Canada?
  8. #67
    Jan 2016
    Ontario
    Actually, you are probably right, I think mercury has been outlawed in Canada. Definitely no mercury thermostats available any more. Do you have the right one for Hunter fireplace?
  9. #68
    Mar 2001
    Ilwaco, Washington
    Give me W/R Number
  10. #69
    Jan 2016
    Ontario
    Give me W/R Number
    I can't find a cross reference to WR. The Hunter part # from the manual is 916243. Also there is a Keating part that looks identical
    https://restaurantequipmentparts-com...h_p_44293.html
  11. #70
    Jan 2016
    Ontario
    Give me W/R Number
    Here is a Robert Shaw part # if that helps FSS130150000. Send me a PM & we can discuss price & delivery.
  12. #71
    May 2017
    I have mercury flame switch which is not working the pilot do not stay and do not lit
    Quote Originally Posted by Mobeer View Post
    Hi I have the same issue with a mercury flame sensor. Sticker says Invensys FSS130150000 on the metal it says Robertshaw and it looks exactly like the Keating 37406 But does it work? and will it work? I think I will try it and see it's a lot cheaper than a new fire place .What do you think?
    Where can I get mercury flame switch or what is the next remedy,old direct vent built in fireplace
    please I need your help
  13. #72
    Jan 2016
    Ontario
    Apr 2017
    Canada, BC
    You should read the thread for a full explanation, but the short answer is your options vary depending on where you are, which fireplace you have and if the manufacturer has a retro kit available. Find your fireplace brand, model, and serial number and contact the manufacturer. If the manufacturer no longer exists you are hooped.
    Where I am (Canada, BC) only manufacturer certified components can be used to repair these, and you cannot just replace the switch the entire flame safety system including the valve and the pilot assembly must be replaced. The replacement parts must be manufacturer certified, adhere to applicable safety standards, and include certified instructions.
    There is a good chance the entire fireplace has to be replaced or decommissioned.
  15. Likes gap1927 liked this post.
  16. #74
    Apr 2017
    Canada, BC
    Gap, have you talked to your gas inspectors where you are? Will they allow this as a replacement part?
  17. #75
    Apr 2020
    Napoleon fireplace GD1800-NM mercury flame switch WS660-4
    I have a Napoleon gas fireplace that was installed in 1992. Apparently the contractor never installed the memory/mercury flame switch. I have other parts that have failed and unless I find the switch, Napoleon will not sell me any new parts and they obviously do not have any mercury switches in stock. My fireplace is model GD 1800-NM and I believe the switch part number is WS 660-4. Do you happen to have a switch available or know where I can find one. We are selling our home and trying to avoid the cost of replacing the entire unit. Can anyone out there help?
  18. #76
    Nov 2009
    Simcoe, ON Canada
    Flame switch is a part that is installed at the factory when the fireplace is built. If it is missing then someone removed it at some point in time. There have not been any of these available in years. Sorry but I think you are looking at a new fireplace.
  19. #77
    Apr 2020
    Do you know what the part looks like? Where can I find a photo of the part, so that I know what I am looking for.
  20. #78
    Apr 2020
    Do you know what the part looks like? Where can I find a photo of the part, so that I know what I am looking for. I want to make sure whether it is really missing on my fireplace. I am not sure what I am looking for.
  21. #79
    Nov 2009
    Simcoe, ON Canada
    Beige ceramic bulb with two spade terminals and a silver colored wire coming out the opposite side, usually located with on a bracket in the lower louver area with a wire going to the th/tp connection on the valve and fastened to the bottom of the burn chamber of the firebox
  22. #80
    Apr 2020
    Thank you.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
