Page 4 of 4 FirstFirst 1234
Results 61 to 69 of 69
Thread: Your Favorite HVAC Tool
  1. #61
    Apr 2020
    Garner NC
    i will say my adjustable a frame 22' ladder. i do a ton of commercial work so it is used quite often. lots of different height drop ceilings also..i only need this one to do it all not 2-4 different ones..
    i put on on my 800-1000lb rated adjustable handtruck to roll it around..milwaukee used to make it...there is no damn way im lugging compressors and all recovery equipment through buildings..to get to the roof..
    https://www.wernerco.com/us/products...MTSeries/MT-22
    https://www.harborfreight.com/4-in-1...uck-70027.html
  2. #62
    May 2015
    New Orleans, LA
    A trusty Digital pocket themometer that actully fits in your pocket. A LED Mini Mag Light ( always attached to your belt) . Feildpeice SMAN 460 manifold make charging a breeze, and feildpeice JL3 Job Link Charge and Air Kit make troubleshooting so easy since you can see everything going on in a system . also my 18 volt cordless drill( because who is really going to take out 30 5/ 16 screws with a nutdriver?)
  3. #63
    Aug 2020
    So California
    Torque wrench on line set flare nuts and service valve caps.
  4. #64
    That make me remember that my young son saw me at the dinner table one day and was talking to someone else there - telling a story or something. I overheard him say: "popeye arms" and said:
    What are popeye arms?
    Everyone laughed and said: You know what Popeye looks like - he has those really huge forearms.
    Sure but so what? Who has 'popeye arms' in real life?
    (a chorus You do!
    No I don't - my arms are pretty regular.
    No they're Not - make a fist! You have freakish forearms! <g>
    So I tighten all the muscles in my arms and realize that my forearms were kind of big. <g> I had never even thought about it before overhearing the original comment. The after-dinner discussion went on to Why/How my forearms were that way and I slowly rotated my hand and watched and felt how the muscles moved. And suddenly it came to me: I had probably screwed and unscrewed a million screws in my life with my hands. Endless equipment opened up and then buttoned up - all done just using nutdrivers and screwdrivers. <g>
    Your comment just made me laugh. <g>
    PHM
    Quote Originally Posted by Melting_in_NOLA View Post
    . . . . . also my 18 volt cordless drill (because who is really going to take out 30 5/ 16 screws with a nutdriver?)
    PHM
    The conventional view serves to protect us from the painful job of Thinking
  5. #65
    Aug 2013
    How about a Phase/ Rotation checker? Relatively cheap.
  6. #66
    May 2015
    New Orleans, LA
    This is gonna make me look like a total hillbilly to most of the guys out there. But my phase checker , if it is not already built into the equipment , is ......
    RUN TO THE DISCONNECT and turn it off when the compressor makes that ........ Sound. You know . Reverse rotation sound.
    It is that simple and if you look at some of the technical information , a very similar process is described ( just with out running at the disconnect screaming and waving your arms like the kid from home alone.)
    Sent from my S61 using Tapatalk
  7. #67
    Jan 2010
    Sea to Sky
    If you did that with a screw compressor, it would likely be toast before you pulled the disconnect.
    Sent from my SM-G965W using Tapatalk
  8. #68
    May 2015
    New Orleans, LA
    Quote Originally Posted by sunsurp08 View Post
    The only reason why I do not own a phase checker , is that the last time I price checked them, they were at least $600 for the most basic model. I'm sure they are cheaper now. I hope .
    Although 90% of the equipment I start these days has one built in, sooooo.....
  9. #69
    Apr 2020
    va
    Try $20 - $300.
    Used this one since ~1980: Sperry LED Phase Sequence and Open Phase Indicator, Item no. 3592508 |PSI8031 $99.
    Equipment meters typically check only the incoming power, not at the compressor leads. Option on scroll chillers and ac, not on most pump starters.
    Cheap insurance tool.
Tags for this Thread
