Results 1 to 20 of 25
Thread: BACNet IP vs Ethernet
    May 2008
    Mid-Atlantic
    Good morning,
    Can anyone help me by explianing the difference between BACNet over IP
    and BACNet over Ethernet? I was just asked and I don't know.
    Melbourne,Aus
    Talking
    One is by the IP address & the other is about the MAC address
    Check out http://www.niagara-central.com/ord?p.../BlogEntry/121
    May 2008
    Mid-Atlantic
    So....... The only difference is IP vs MAC? Are there any other considerations?
    Melbourne,Aus
    It depends on what Hardware you are using....what system do you have????
    May 2008
    Mid-Atlantic
    This is a JCI NAE. I got a call form one of my tech cohorts He is setting up a chiller thru BACNet and the chiller tech asked how he wanted it setup.
    I read the link you sent {thank you!} I need to sit quietly and read that more
    completely, and I think I understand but BACNet is just catching on here and the learning curve is steep. Still fumbling if you know what I mean
    any sugesstions??
    dynawiderider
    Melbourne,Aus
    Give Freddy-B a yell as he is up with JCI gear.......
    I can only help U out with chiller stuff......!!!!!
    May 2008
    Mid-Atlantic
    Thanks, How do I get a hold of him?
    Concord, NH
    Quote Originally Posted by Dynawiderider View Post
    Keep in mind that BACnet Ethernet is NOT routable. The devices need to be on the same subnet in order to communicate.
    BACnet/IP is routable, but you'll need a BBMD (BACnet Broadcast Management Device) in each subnet for communication.
    Melbourne,Aus
    Do a search on freddy-b and you can get his email from his profile.
    Mar 2006
    Its really easy to set the NAE/ADS up as a Bacnet site.
    All you have to do is double click on the "Site" its the Top menu of all items tree. Then on the right hand pane a you will see the site info. Click advanced tab, more options appear, and about 3/4 of the way down the page there is a check box to enable the site for Bacnet. Then discover, and if your setup right on the other end you should see your chiller data.
    Freddy
    NW Ohio
    The NAE would BACcrap IP (not BACcrap Ethernet) after setting the site as freddy said.
    May 2008
    Mid-Atlantic
    Thanks for the input..........I will use it for good not evil!
    Melbourne,Aus
    Quote Originally Posted by NINAX View Post
    Just trying to help people out with a constructive reply! Who are you?? Rolo-2??
  14. #14
    NW Ohio
    Quote Originally Posted by Ausccn View Post
    What is your problem!?!
    I stated the NAE will be BACcrap IP!?! Do you disagree! Educate me!!
  15. #15
    Melbourne,Aus
    So you dont like BACnet!! And I dont have a problem..Case closed.
  16. #16
    NW Ohio
    OK!
  17. #17
    Melbourne,Aus
    So where did you do your Tridium training??
  18. #18
    NW Ohio
    If your question was directed to me,
    3957 Westerre Pkwy, Richmond, VA
  19. #19
    Melbourne,Aus
    I actually did training on Tridium back in 2003 in LA seems a pretty good product but of course that was R2 and we have basically dumped that now for ALC!!!!
  20. #20
    NW Ohio
    It's never too late, Aus Vader.
