Results 1 to 20 of 43
Thread: Lifting/Rigging Tool´s for Trane CVHF 1280 Compressor teardown/overhaul.
    Oct 2009
    São Paulo - Brazil
    Can anybody help me out with lifting tool equipment for cvhf 1280 compressor?
    The bulletin CTVH-GCO-03 refers to this manuals: CTVH-GMS-01 and CTVH-GMO-01...(Cant´t find).
    I already have the drawings to pull out the first stage inlet guide vanes assembly...
    I need the drawing´s for the suction cover lifting tool and the 2nd guide vane assembly.
    Thanx!!!
    in a tree looking in your window
    Come on man, having all the proper tools takes all the fun out of it. Seriously though I think the hardest thing is pulling the first stage vane assembly and it sounds like you have that covered. There are a few examples of vane pullers here
    http://hvac-talk.com/vbb/showthread....11#post1818111
    my post was # 21 and there is a pretty good tool in post #24. Everything else pretty straightforward, some shackles on the top of the suction cover and a couple of eye bolts where the suction ell bolts up and your good to go. Just have plenty of chain and guide pins.
    up in the hizzy
    see if this helps
    Attached Files Attached Files
    Oct 2006
    Central Texas
    I don't think trane even puts out the vane lifting tool or the casing tools anymore. I use shackles, straps, and lifting chains. You should really go to school on these & get some instruction. A 1280 ton ain't a little machine, the components are heavy. Be cautious.
  5. Likes CHILLERSVCMAN liked this post.
  6. #5
    philadelphia
    Chain with chain hooks for the donuts and creativity for everything else, it's really straight forward the worst part is finding where to hang the block if you don't have room for a gantry.
  7. Likes CHILLERSVCMAN liked this post.
  8. #6
    Jan 2015
    Northern colorado
    To pull the vane assembly you can use an 8' 4x4 lodged between the vanes, use a strap as close to the vane assembly as possible(attached to your 4x4 and your chainfall as your fulcrum point). Have some one hold the far end of your 4x4 and loosen your set screws. Just be ready that the vane assembly will just slide out and the 4x4 will take the weight. If the person holding the 4x4 puts a little load on it, it won't be as surprising. I found this in an old document and can send you if needed.
  9. #7
    Oct 2009
    São Paulo - Brazil
    Works perfect...I used the original Trane Drawings but with some changes...
    Click image for larger version.
ID:	555051Click image for larger version.
ID:	555061Click image for larger version.
ID:	555071Click image for larger version.
  10. #8
    That's not real rigging...look at how much room you have! Tools look nice!
  11. Likes CHILLERSVCMAN liked this post.
  12. #9
    Oct 2009
    São Paulo - Brazil
    Yeah...Thanks God we got a lot of space here in Brazil...Show me some real rigging then...
  13. Likes dieseldude liked this post.
  14. #10
    Jan 2010
    Quote Originally Posted by jayguy View Post
    What... everyone doesn't get an overhead crane
  15. Likes dieseldude liked this post.
  16. #11
    Nov 2008
    This ones not to bad.... a little tight
  17. #12
    Mar 2014
    NC
    I agree with txhvac. Those rigging tools are just something else heavy to get up in the air. Slide that suction cover back with guides and put the chain through the inside.
    I like your rigging tools triggerhappy. Putting those steel beams up always suck though.
  18. #13
    philadelphia
Name:	Rigging Picture.jpg
ID:	556021Click image for larger version.
Name:	Rigging Picture 2.jpg
ID:	556031Here is one just getting started on this week not the worst for room but not the best either.
    The tools for the Trane chillers are nice.
  19. #14
    Dec 2003
    45th Parallel
ID:	564691Click image for larger version.
    This is a 1280 I did about 11 years ago. Had to build a permanent structure around the chiller rated for at least 7,000 Lbs. Enough to suport motor and Discharge volute at same time, everything had to come off the suction el end of chiller. Good times!
    “If your work speaks for itself, don't interrupt.” ~Henry J. Kaiser
  20. Likes CHILLERSVCMAN liked this post.
  21. #15
    Oct 2011
    South Georgia
    In looking at the picture of the suction elbow rigging I noticed something in the way the hooks are attached into the straps. Maybe I am not quite seeing the whole thing but I would have turned those hooks over down into the straps. That way the side loading angle would not pull toward the open side clasp. Anyone else agree or am I not looking at this correctly. One thing for sure, you have to respect those CV teardown situations. Looks like you had a challenge there.
  22. #16
    Apr 2006
    mechanical room
    you guys are crazy
  23. #17
    Anaheim, Ca.
    Does anyone know of a part number for the threaded taper pins? I think they look like a #8, but I didn't know if Trane actually has a part number, since they don't show them in the manual. Thanks!
  24. #18
    Apr 2016
    Maryland
    Being a chiller mechanic is more than brushing tubes and changing oil filters.
  25. #19
    Apr 2016
    Maryland
    Trane does have a part number ; I think it maybe " PIN008 " .That should be the tapered pin threaded with nut ; as opposed to a smooth tapered pin .
  26. #20
    Apr 2016
    Maryland
    Carrying the beams up / down multiple flights of stairs is a workout !
