Page 5 of 5 FirstFirst 12345
Results 81 to 99 of 99
Thread: wanted QVM9 quietside parts
  1. #81
    Nov 2018
    Try Solar HVACR Supply in Santa Fe Springs, CA at:562-948-2999. I was able to get several parts from them in the past.
  2. #82
    Mar 2011
    Hamilton,Ontario.Canada
    Quote Originally Posted by wegme27 View Post
    I have a DPW-120 and am looking for a three way valve. Part number I believe is 2040119. Thank you.
    where are you located?
  3. #83
    Mar 2019
    Quote Originally Posted by mikeyflowerguy View Post
    Located in central Pennsylvania
  4. #84
    Mar 2019
    Quote Originally Posted by tsuchocki View Post
    I just called them but they were out of that part. Thank you though
  5. #85
    Mar 2011
    I will look in my stock....pretty sure though...
  6. #86
    Mar 2019
    Ok thank you. We are not sure if that’s the exact problem but are trying to troubleshoot by ourselves. We can’t seem to find anyone that wants to work on it just wants to replace it and charge an arm and a leg. Our issue is it fires up and the temperature gets too hot so it throws the AA error and turns it off so the temperature drops, once below the set temperature it turns back on and repeats the AA error and we don’t have DHW. Yesterday I got the A4 error code shut the system down and restarted it and now we have semi warm DHW. I called the line for the recall and they are sending the repair kit out. No clue if that will help.
  7. #87
    Mar 2011
    what is your water source....the BIGGEST issue with the DPW's was the DHW exchanger getting COMPLETELY/partially plugged up!! Big problem in the older QVM series...the safety repair kit has NO bearing on this....
  8. #88
    Mar 2019
    We have a well so is that what you mean for the water source? Where is the exchanger at and is that something we could clean ourselves?
  9. #89
    Mar 2011
    Well water, and unconditioned city water KILLED Quietside.....poor water IS the primary failure source on nearly ALL early versions of ANY of the boiler builders. I tried extensively trying to clean, unclog the closed cell heat exchangers with NO luck....let me check a couple things...
  10. #90
    Oct 2016
    QVM9 QuietSide Parts
    I still have more parts for qvm9. See attached for part numbers. Page 39,40,41
  11. #91
    Nov 2019
    Homeower
    Quote Originally Posted by helper777 View Post
    Our ministry that helps the homeless and those in need is looking for parts for our QVM9 quietside tankless water heater/boiler. We can't afford a new unit and was hoping someone had an old unit that they took out would have some parts. We are mostly looking for the control board but figure other parts in our unit will eventually go out - so want to plan ahead.
    Thank you.
    I have piles of Quiteside parts new and used. Three boards two brand new.
  12. #92
    Nov 2019
    Homeower
    I have many many new and used quiteside on demand hot water (gas) parts for sale. Three control boards two are brand new still in the box
  13. #93
    Dec 2019
    New Jersey
    Quote Originally Posted by PAW View Post
    Do you have : C20901011B - BH1301010A Heating Strainer for OVM9-125W1-NG?
  14. #94
    Jan 2020
    Hi PAW
    I have a DPW-120, installed 1/14. do you have anything for this unit? Right now I have a very seepy leak from the Cold Water inlet, not sure if from the Inlet nipple (p/n 3030193) gasket or o-ring, or if the Flow Switch is leaking (p/n 2060229). Haven't really had many problems yet with this boiler. Are there any common failures you know of?
    Thanks.
  15. #95
    Dec 2020
    Hi PAW, do you have circulation pump for quietside dpw 199a ? The number on the pump is cs-0530dsb. Thank you.
  16. #96
    Nov 2021
    Hi i am looking for for part number 2040124 ( motorized 3 way valve) for quietside dpw 199. it would be great if you have it any chance. thank you
  17. #97
    Jan 2022
    Does anyone know if the High Limit Fuse on the Quietside QVM9, part #C22203009A is a common fuse or specific to this unit. If specific, does anyone have it available?
  18. #98
    Jan 2022
    Do you still have parts for Quietside
  19. #99
    Jan 2022
    Hey PAW, Do you have #2070457 heat exchanger assembly for DPW 120 and a #2100285 air pressure switch
