We are preparing to replace the HVAC heat pump for our "bonus room", which is less than 500 sq.ft and is not used regularly. We are looking for something inexpensive (we replaced our main unit 2 yrs ago with an 18 seer Infinity system). I have had 4 Carrier dealers come out and provide me with quotes and I have a few questions. I'm looking for inexpensive, the "Fiat" instead of the "Cadillac" in this case - read 13 seer.
Currently we have a 2-Ton unit, 3 of the bidders suggest replacing with a 2-ton unit, 1 bidder suggests going down to a 1 1/2-ton unit. The 2-ton bidders argue that the cost difference is so small, it is better to put in the 2-ton. Interestingly, the 1 1/2-ton quote is by far the highest. Which would you recommend?
All 3 of my 2-ton quotes are for the same indoor unit, same heater, same thermostat. One of the bids (the cheapest) has a different condenser. I would like to know what the difference is between the 2 units. CH14NA024 and 25HCD324A003. I understand the CH unit is a "builder grade" and the 25H unit is from the comfort series. Besides that, I do not know what the differences are. Is one going to be significantly louder? Cheaper parts? Which would you recommend and why?
Thanks so much!
Thanks so much!
