Results 1 to 8 of 8
Thread: Motor Run Capacitors
    Virginia
    Confused Motor Run Capacitors
    The general rule is that once a capacitor get 10% below it's rated Uf value, it needs to be replaced. I've seen capacitors that aren't leaking or bloated, and are 25% below their rated value, and they still seem to be working fine; or are they working as they should? My question is: once a compressor or evaporator fan capacitor loses more than 10% of it rated UF output, is the fan motor running at a slower rpm? What is really happening to the motor when the capacitor isn't at it's full rated capacity?
    Jul 2001
    Delaware
    Chances are
    the motor is going to be drawing high amps if the cap is weak.
    Work is for people who don't know how to fish.
    Raleigh, NC
    Grady White is right. The cap helps the motor develop torque. If the cap is going bad, then the motor will draw more current to get the required torque.
    The greatest enemy of knowledge is not ignorance, it is the illusion of knowledge
    ...It is better to be a little smarter than you have to be, instead of a little dumber than you should be!
    MN
    Agreed, caps are cheap, replace it.
    S**t or get off the pot!
    Virginia
    Thanks for the info
    Maryville Tennessee
    I was once told in a class that capacitors have a 100% failure rating.
    Quote Originally Posted by rundawg View Post
    i thought it was +or- 6% ofits ratting
    MN
    Quote Originally Posted by LBDavis View Post
    I've always gone by +/- 10%
