I had a local Trane dealer out today to quote me a new system, 3 Ton a/c and gas furnace. I was hoping to get two stage cooling around 16 SEER with the 2 stage furnace. After measuring everything and going through the AHRI matches, he said that matched with the xr16(which is now called xr18 he said??) that the seer would only be 14.5 and I would have to have either the 80K or 100K(can't remember) btu furnace to get this because of blower. Obviously he steered me away from this match as a waste of money for the purchase price of the high seer condenser versus the seer rating I would get, and the furnace would be massively over-sized. He said the only way to get the higher seer is to go with the new variable speed condenser and a communicating furnace.
What we settled on quoting me was the 60,000 btu xv80 with the xr15 single stage condenser. this would give me seer of 14.25.
He will also quote me a higher seer heat pump system, but wiring will have to be pulled to make that work.
I guess my questions are does this sound legit? Why won't the two stage condenser work properly at rated efficiency with the smaller furnace? All the specs I've read say that the blower will handle 3 ton cooling.
Also, I can't seem to make the AHRI website work at all for Trane equipment. No problem finding Rheem or Goodman matches, but I can't get any results for Trane. Any suggestions?
Thank you in advance for your help.
