+ Reply to Thread
Thread: Where is ralph when you need him?
    Victoria,Tx
    I have a 4 bedroom house and 3 full baths. Since it is just Cheryl and I here, the other two baths hardly ever get used. That means the tub's, showers, potty's and lavatory's. Question is, Is it ok to let the water just set there in the copper pipes or do I need to turn the hot and cold water on sometimes. The back bath hasn't been used since Cheryl bathed Lulu. Ha, I miss the little pig.
    Seems to me run some water occasionally. If my feeble memory is right, seems a member of "The Wall" got Legionaire's disease from stagnant water in the pipes of his vacation home. If you don't keep it fresh, run lots of water before drinking or showering in that part of the home.
    Jan 2006
    In a land far, far away
    More important than the supply pipes are the drain traps. You need to run water ever so often to keep the water seal in the traps from evaporating. If they do sewer gas can back up into your home, besides stinking it can actually be flammable.
    Illinois
    Sorry, I snuck out early and went to a tool auction.
    It's probably a good idea to run some water in those occasionally. Keeps them from drying out, and also rinses whatever residual cleaning chemicals might be down there. If you've got copper dwv, you do not want to use any chemical drain cleaners, or that tile & grout stuff from the annoying guy on tv. It'll sit in the trap, and eat right through the pipe at the waterline.
    "If I had my life to live over again, I'd be a KA." - Albert Einstein
    It's later than you think.
    PDX
    Quote Originally Posted by ralphtheplumber View Post
    Same story if ya got Durham drains as well... Some of them are so worn out, they are paper thin!
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
