+ Reply to Thread
Page 2 of 11 FirstFirst 123456789 ... LastLast
Results 21 to 40 of 215
Thread: Rapid Rise of Solar Tech
  1. #21
    anywhere my RV is
    so basically, none of these inventions will trickle down to the consumer for at least 25 to 30 years.
    There is still no *affordable* solar power for the NIMBY crew. There is only massive power projects that will cost billions upon billions of dollars with ZERO ROI
    swell
    Why am I the only naked person at this gender reveal party
  2. #22
    Atlanta area
    Quote Originally Posted by jmac00 View Post
    swell
    Yeah, right.
    Bear in mind that the rate of technological advancement is exponential, not linear.
    While we're on the subject, check these out:
    Graphene-based solar cell hits record 15.6 percent efficiency
    http://www.gizmag.com/graphene-solar...iciency/30466/
    Organic flow battery could transform renewable energy storage
    http://www.gizmag.com/organic-flow-b...storage/30433/
    Vacuum Technology:
    CRUD = Contamination Resulting in Undesirable Deposits.
    CRAPP = Contamination Resulting in Additional Partial Pressure.
    Change your vacuum pump oil now.
    Test. Testing, 1,2,3.
  3. #23
    Jun 2013
    Austin, TX
    "Efficiency" is mostly irrelevant for stationary applications. It's total $/W that really matters.
  4. #24
    Aug 2009
    Maine
    A guy in Gray Me spent about 20K on Solar, he is putting in a ductless split system. He has no batteries, the power he doesn't use goes back into the grid and he gat a credit.
    Although I like the whole idea, his payback must be 20 years although I am sure he got tax credits. I hope he doesn't have any problems and or major repairs.
  5. #25
    anywhere my RV is
    Quote Originally Posted by Space Racer View Post
    Yeah, right.
    ok, these "batteries" have my attention. WHAT organic material are they using??? what exactly is the DOD (Depth of Discharge) around here you need enough battery storage to last a minimum of three days~~~without sun before you need to recharge the batteries or start a generator to charge the batteries.
    So if these organic batteries only last one full day and then need to be recharged, that maybe a problem
  6. #26
    anywhere my RV is
    Quote Originally Posted by lytning View Post
    ya, thats a "grid tie" system. you're still tied to the utility system.
    Im trying to get rid of the utility company by going "off grid" My dream is to one day call RG&E (Rochester Gas & Electric) and tell them the meter is laying in the front yard, come get it
  7. #27
    Aug 2009
    Maine
    Sounds like a great plan. Costly, but good.
  8. #28
    anywhere my RV is
    exactly, it will be a few years before there is any ROI.
  9. #29
    Atlanta area
    New Polymer Could End Battery Fires, Quadruple Efficiency
    Lithium-ion batteries are at the heart of the phones, tablets, cars, and planes we use every day, but they have an inconvenient habit of occasionally bursting into flames. Now, a team of scientists have found they can replace the unstable, fire-prone chemicals in batteries with an exceptionally stable polymer.
    http://www.wired.com/autopia/2014/02...mable-polymer/
    Vacuum Technology:
  10. #30
    anywhere my RV is
    oooh man, if they could make these batteries commercially viable, that would be fantastic
  11. #31
    Atlanta area
    Stacking Method Enhances Solar Power Efficiency
    The stacking method involves placing several solar cells on top of each other, and is at present the most efficient form of social power installation on the market, capable of converting 45 per cent of the sun’s energy they harvest into power.
    http://sourceable.net/stacking-metho...er-efficiency/
    Vacuum Technology:
  12. #32
    Atlanta area
    Musk may reduce battery cost as much as 40% by building a factory.
    http://nextbigfuture.com/2014/02/elo...ry-market.html
    Vacuum Technology:
  13. #33
    anywhere my RV is
    so I looked into this "stacking", it's not anywhere near ready for consumers and it maybe years or decades before it is. It is an a great idea though. But it seems it produces a LOT of heat. and heat is bad for a solar panel.
  14. #34
    Sep 2009
    Marietta, GA
    Hey Jmac, you don't have a solar water heater system at your cabin? Solar water heater systems I think give the best ROI compared to solar panel systems.
    wHen I diE I hOpe gOd haS mErcy oN my SiNful LifE
  15. #35
    anywhere my RV is
    Quote Originally Posted by mofotech View Post
    not-a-chance, it is seasonal property, we only go up north in the winter once or twice on a weekends (maybe once in Jan and once in Feb) and we go when we know it's going to be at 30° or greater.
    This morning it was MINUS 5° with a 8-15mph wind.....wind chill would be around minus 13 to minus 25.
    when we close up for the winter, we drain the water and sewage systems and put in anti-freeze that good to minus 50.
    The solar panels are strictly for lights and water pumps, and the ceiling fan when its sunny enough.
  16. #36
    The thing is, if the tax dollars that are being flushed down the solar/wind energy toilet was redirected to developing and building full scale Thorium salt nuclear power plants, we would have all of the clean, relatively cheap, and intrinsically safe electrical generation we could ever need...
  17. #37
    Jun 2013
    Austin, TX
    They should end oil subsidies first.
  18. #38
    Atlanta area
    New commercial PV cells achieve >22% efficiency.
    http://ir.trinasolar.com/phoenix.zht...732&highlight=
    Perovskite PV efficiency is on the rise.
    http://www.theguardian.com/sustainab...re-solar-power
    Vacuum Technology:
  19. #39
    Atlanta area
    Another article on stacked cells
    How It Works: The Highest-Efficiency Solar Cell
    http://www.popsci.com/article/techno...ncy-solar-cell
    Vacuum Technology:
  20. #40
    Atlanta area
    Vacuum Technology:
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
