Moved into an existing home in Iowa over the summer and now that heating season has arrived I have some questions about the way that the system is operating. These seem like the types of questions that would come up frequently, I did use the search feature. Sorry if this is repetitive.
I have a Lennox HP26-036-12P (manufactured January of 2003) air source heat pump with a Lennox CB19-41-2P central unit with one 20kW stage of electric heat (manufactured in July of 1992) and a Lennox Elite Series thermostat (purchased in July 2007). The home has about 2000 sq ft of conditioned space and was built in the early 1980s. Insulation is OK, but not great.
When I moved in, the heat pump compressor lockout (thermostat setting 0350) was set at 35 degrees. When the temperature approaches 35 degrees, the heat pump runs less than 25% of the time, even at night. Also, both the heat pump and the electric backup run on very short cycles. At this point, I do not think that I have heard the aux heat run more than 2 minutes at one time or the heat pump run more than about 5 minutes.
My understanding was that the heat pump should be left on as long as possible and the electric heat turned on as necessary to maintain the set point. I spoke with one professional and he recommended that the heat pump be locked out at 35 degrees on principle. Is there a reason why the set point would be set so high when the heat pump is clearly capable of heating the home at that temperature? Should the heat pump ever be locked out if the backup heat is electric? Is there a minimum operating temperature for the heat pump?
Both the heat pump and the electric heat seem to turn on and off frequently. Is this normal for a heat pump system? Is there a way to change the thermostat settings to have the heat run longer and less frequently?
I read through the installer's manual for the heat pump and there are settings for the cycles per hour for the various system operating modes (settings 0230 through 0270). What do these settings actually do?
Thanks for the help!
