Hi, Good Day to all,
is that possible to analyse an aircooled condenser efficiency with psychometric chart what will be the efficiency in high humid cities.
Thanks.
what about the evaporator and overall efficiency?
humidity does not have as great an impact on a air cooled condenser as it would an evaporative condenser. dry bulb is the primary force here. That said, as the humidity rises, so does the heat capacity of the air, so 100% humidity would cool the condenser better than 50% humidity at the same dry bulb.
Thank you all for explaining.
