Results 21 to 28 of 28
Thread: Small wind generators < than 1000 watts
  1. #21
    anywhere my RV is
    Quote Originally Posted by RexCauld View Post
    Haha, you should write stories
    Thanks for the sheet metal tip. And for sharing your experience!
    no problem, have fun, good luck
    FEAR TACTICS
    DON'T WORK ON WARRIORS
  2. #22
    Feb 2015
    Coastal South Carolina
    Quote Originally Posted by jmac00 View Post
    I think the Tankless 202 was originally designed for farmers that want to pressure wash their equipment with hot water. its designed to installed outside the building/cabin/home.
    I put a large sheet of sheet metal behind mine to keep the mice out.
    I noticed you are using PEX plumbing. Is this exposed to sunlight and if it is do you have any problem with it failing due to the exposure?
  3. #23
    Feb 2015
    I see lots of sail boats here on the inland waterway that have small wind generators mounted on them, might look into a West Marine or other supplier for more insight.
  4. #24
    anywhere my RV is
    Quote Originally Posted by safebustr View Post
    sorry for not responding sooner its been a little crazy around here. The Pex has only been up since last year. it hasn't been up long enough to really 'test it'. even if it does deteriorate some, we can always wrap it with insulation, which I might do anyway?
    FEAR TACTICS
  5. #25
    anywhere my RV is
    I think at this point, I would stick with solar panels. those little wind generators tend to make a lot of noise and do require some maintenance. PV panels just sit there and do there thing, no maintenance and wait for rain to wash them
    FEAR TACTICS
  6. #26
    Apr 2020
    va
    Anyone have experience with the dual purpose solar collectors? Parabolic, hot water & electric?
  7. #27
    Apr 2020
    va
    Vendor claims:
    "Solar PV-T solar panels combine a patent-pending heat collector with generic PV cells to create an integrated solar panel that increases electricity output with additional thermal energy.
    Compared to PV alone, Tyll Solar PV-T systems offer more:
    A BETTER SYSTEM – About 80% of the sun’s energy is utilized, compared to only 15-22% efficiency with PV panels alone where the balance of solar radiant heat is lost. Tyll Solar PV-T panels capture much of that wasted heat, converting it into usable energy by generating hot water.
    4X MORE ENERGY – Tyll Solar PV-T panels produce 400% MORE energy – both electricity and hot water – using an identical surface area."
  8. #28
    Poodle Head Mikey's Avatar
    Poodle Head Mikey is offline Membership Chair/ARP Committee / Professional Member*
    The water's not gonna clear up in Washington DC until we get the pigs out of the creek.
    I had a 50 watt and later a 100 watt unit on a sailboat. 2 Group 29 batteries were maintained by the 50 and 3 by the 100. I still have the tired old 50 but the blades are no longer available, I only have three or four, and I have never been arsed to make them myself.
    Wind generators are pretty common on cruising sailboats - and are made to withstand a salt air environment - so I would be looking there first.
    PHM
    anyone have any experience with wind generators for weekend/vacation cabins
    I have an off grid cabin that I power with solar panels, but I want to install a wind generator that's less than 1000 watts.
    anyone know which small generators are good, which ones are not-so-good
    PHM
    The conventional view serves to protect us from the painful job of Thinking
