Results 1 to 7 of 7
Thread: UPCM edit
    Feb 2011
    Illinois
    UPCM edit
    We have recently taken over a contract which has Tracer Summit. There are UPCM controllers which I have access using UPCM edit software through Summit. I would like to have the software on the laptop to connect directly. However the software on the Summit front end is extracted into many files. Is there a way to copy these folders/files over to the laptop so that it is operational?
    Believe you just take both UPCM folders that are in the Summit directory and copy them to your PC.
    Feb 2011
    Illinois
    I do not have Summit on my laptop. Also, there is no executable files in the folder. Since it is a DOS program, I don't understand how to 'run' it.
    You are correct, i did not look close enough at my summit install. It must be built into summit using dll
    Feb 2011
    Illinois
    Can Rover software be used to configure UPCM or PCM controllers?
    May 2003
    Connecticut
    Quote Originally Posted by mikeul View Post
    No, You need pcmedit or upcmedit
    Feb 2011
    Illinois
    Where can I get upcm and pcm edit?
Tags for this Thread
