Results 14 to 26 of 52
    Valdosta Ga
    I understand these guys have to produce out of the school , but what does this speak of our education system an is our industry getting involved enough.
    Oct 2011
    Chicagoland Area
    What did you expect? I mean there are 3 different colored wires.
    I had a helper do something similar. Installing an evap coil on a WIC. I told him to wire the fans and tstat parallel. He wire nutted the hot and neutral on the whip together, as well as the leads for the fans, and the leads for the stat/solenoid. Had to go on a call back for another guy who installed a 3 pole switch on a single phase ice machine. Installed the leads across from each other rather than next to each other and swore it made ice before he left. The only thing it made was smoke come out of the breaker panel.
    I had a call a few years ago on a boiler our guys installed that day. Called about 8 pm, said "the new boiler works great, but it's a bit too warm in here".
    I found the same wiring job your guy did, but it was the t-stat wires nutted together, and the control leads on the boiler wired together.
    82 degrees and climbing!
    Never let the helper do the wiring, no matter how simple it looks.
    Just because it turns on, it doesn't mean it will shut-off!!
    Northeast, PA
    2old2rock
    I love your quote: "Just because it turns on, it doesn't mean it will shut off". I plan on using that the next time I rewire a heatpump thermostat that someone else installed. Thanks!
    Valdosta Ga
    Some of these helper folks turn out to be great. We all have a different way of doing things Even if we drill holes through a boiler or a wire bundle. to put rivets in the insulation
    I honestly think its great you can take the responsibility of a on the job trainee Because in the end it may just be you explaining what went wrong sometimes .
    Every day there are changes to this field and if you are out of it for few years the changes will be hard to keep up with also when the jobs are few its hard to keep a good experience level.
    Jul 2009
    Columbia, MD
    so whats the answer to the question? haha ("You are in a room with 3 light switches. You need to find out which one controls the light bulb in the next room. You can make only one trip to that other room to see which one is lit. How do you do it?")
    my educated guess is turn all 3 of them on and take a extra lightbulb with you...or have one guy look at the light while you flick them on
    May 2009
    California's Butt-hole
    Wow, that's just to funny. Did this guy come from a school or was he just a walk in?
    FROM A SCHOOL YOU MUST POST
    Jul 2009
    Quote Originally Posted by gravity View Post
    You figure out which one(s) control the light in the room you're in. If only 1 remains, thats the one. if 2 remain, you check one. if its not it you know its the other... The only caveat is if they tricked you and wired the lights in both rooms to the same switch.
    May 2009
    MacGyver Agrees white always goes to Red....never cut/splice the green one.
    Never use wire connectors.
    Oct 2009
    The new green wiring code says a light switch must be located in the same area as the people the light will annoy. Red tag it!.
    Never argue with a crazy man.
    Oct 2009
    Smile
    Quote Originally Posted by numbawunfela View Post
    I am usually pretty tolerant of helpers not knowing anything, but HOLY COW!
    I sepent 45 minutes on the way to a call discussing and diagramming hydronic system design (long ride) and I go to get something during the repair and leave him with the tasks to tighten the flange bolts and wire up the pump.
    He finishes and when I come back he asks "is it wired right?"
    Attachment 224802
    I dunno - whaddya think!?!?
    http://youtu.be/oNrnFmlNq30
    A few weeks ago, I asked him to help me do a PM call. Put drain tablets in the drain pan and pour water down the drain to make sure all is well. I come back, and he put the water in the secondary drain pan under the unit, along with the drain pan tablets, and announced 'I'm all done!' Now I hafta spend time drying out the wet switch to get the unit turned on, after we get all the water back out of the auxilliary drain pan.
    the good news is that he is going to school for accounting. -really-
    He didnt tell you thats how the old one that you said had a shorted motor was wired!.
    in a house, Appomattox, Va.
    Lack of common sense- when the wire was loose it wasn't hooked to the pump, and it still isn't. Or, if you could wire nut it like that off the pump, how is it any better closer to the pump?
    Col 3:23
    Jun 2010
    Philadelphia PA
    Mark Twain said:
    Quote Originally Posted by billygoat22 View Post
    COMMON SENSE ISN'T VERY COMMON
    Truth is common sense hasn't anything to do with a lack of structured training.
    I wonder if there is a place to learn available for the helper of the OP
    AND is the OP willing to pay for this helpers education?
