Thread: secret stash
    in a house, Appomattox, Va.
    Pulled the back off a furnace to check the HX (bad return duct/hi static) and found this....the draft regulator that came witrh the furnace. Strangely, there's also one on the flue pipe.
    Col 3:23
    Rochester, MN
    Damn, looks like that bottom has seen better days....
    Where is the air filter??
    No air filter in unit, but three on top of oil tank so we installed one and showed the ho where. Return was not so hot, 80* delta t and .75" esp, mostly return duct fault.
    ho said would call about later, but you know how that goes sometimes.
    Col 3:23
    Jul 2000
    Middletown, Ohio, United States
    Is that what they call a "kilo"?
    delete
    [Edited by happycamper on 10-26-2005 at 08:34 PM]
    If its worth doing, it's worth doing right.
